Best Comp Ratio for 2.4l
Old Nov 25, 2009 | 06:56 PM
3gEclipseTurbo's Avatar
Want 600whp on 93oct pump no meth. I have a 6262 gonna be ording piston & rods soon. So what comp ratio should i go?
Old Nov 25, 2009 | 09:26 PM
dambikeracer's Avatar
10.0:1 is what most are going with these days. I'm going to run 11.0:1 on my 2.1L build
Old Nov 25, 2009 | 09:59 PM
wow thats higher than i was thinking of 8.5:1-9.1.
Old Nov 25, 2009 | 11:14 PM
JohnBradley's Avatar
I wouldnt go less than 9.0 but I am not 100% sure I would go too much higher. My car seems to be working well at 10:1 and made 634whp/531tq (Corrected) at 30psi dropping to 27 relatively quickly but holding to 9k.
Old Nov 26, 2009 | 12:50 AM
John wat size turbo was that with? pump, race gas, e85? Meth?what size motor, 2.4l? so now to narrow it down 9:1-10:1, descision descisions.
Old Nov 26, 2009 | 12:53 AM
3586, straight 92, 2.2, 10:1
Old Nov 26, 2009 | 01:08 AM
im starting to think 10:1 is gonna be my best bet.
Old Nov 26, 2009 | 08:12 AM
ryno529's Avatar
10:1 is really popular right now. you will have more power when you are not on boost as well. The only problem i have found with higher compression ratios is they are a LOT less forgiving on the tune and when things go bad they go really bad.
Old Nov 26, 2009 | 12:05 PM
I did 10,1 because my car is going to be primarily an e85+ car so I wanted the extra compression to take advantage of it. I am not sure that I would necessarily recommend it for a pumpgas car, though mine does seem to work well.
Old Nov 26, 2009 | 12:22 PM
190hpkilla's Avatar
Pump and high comp doesn't seem like a good idea like the above gentlemen recommended.
My 2c is perhaps use 9:1 its more forgiving on PUMP and better throttle response then lower comp ratios.
Old Nov 26, 2009 | 06:33 PM
sparky's Avatar
What peak boost level do you hope to be running on 93 octane pump gas?
Old Nov 26, 2009 | 07:10 PM
atleast 25psi, not sure how much more i know the my tuner has atleast 5 cars i know off running 26psi on 93 pump with 0 knock. So it seems that 9:1 wont yeild as much hp at the same boost as 10:1 but well be safer so 9:1 it is.
Old Nov 28, 2009 | 10:28 AM
You can also alway do 9.5:1 to be right in the middle.
Old Nov 28, 2009 | 10:34 AM
willitas34's Avatar
^^^ I was just about to say the same
If you plan on running 100+ oct and/or e85... go 10.0:1
If you plan on staying 91,92 or 93 pump, I don't think going over 9.5:1 is a very bright idea.
GL!
Old Nov 28, 2009 | 05:53 PM
hokiruu's Avatar
9:1 or 9.5:1 at the higest. If it were me, I wouldn't get too greedy, keep things pretty flexible, and just go 9:1. I'd rather be able to be flexible on fuel and boost than have to base those two on my CR, which isn't quite as easy to change.
