Drive Shaft Carrier Bearings
Old Dec 3, 2009 | 02:30 PM
thermaldynamics's Avatar
Are the drive shaft carrier bearings replaceable (not the mount bushings)?
My drive shaft seems to have "excessive" movement when I push on the shaft from underneath the car. If they are replaceable are there aftermarket urethane replacements? I am having a tough time finding anything on these. I am guessing they are not replaceable because of this.
Old Dec 4, 2009 | 10:02 AM
bump
Old Dec 29, 2009 | 09:48 PM
AWD Motorsports's Avatar
I dont believe they are rebuildable.. Here is an option if your driveshaft seems to be sloppy..
https://www.evolutionm.net/forums/ev...fts-stock.html
Old Jun 17, 2010 | 03:03 PM
Mike,
Sorry I just saw your reply. I know this goes back a little while but they are rebuildable. I put new bearings in mine. I used a bearing splitter to get everything apart after marking the full shaft for balance.
Part Numbers are:
MR553202 (Rear Section)
MR553201 (Front Section)
If I had the money, I would have definitely considered going with your aluminum rear section
charlie.tunah
18
Dec 30, 2019 10:58 AM
Ronnie Size
Nov 23, 2014 06:27 PM
sinstr
May 25, 2013 05:17 AM
qcustoms
Dec 9, 2012 11:25 PM
David Buschur
89
Aug 28, 2010 09:47 PM
