is the Buschur exhuast slip-fit?
Im trying to figure out if a Buschur Down-pipe and Hi-flo cat will fit with an HKS Hi-Power exhuast, but i can't seem to get an answer.
Jarrod at Buschur isn't sure, but tells me that the Bushur hi-flo is a slip fit, which needs a clamp. Will this fit ?
Yes, it is a slip fit. If you have a reducer on your catback you can cut the flange off and slide ours over. This may require some fabricating or welding, it will depend on whether or not your other company produced 3" exhaust is truly 3" or not.
David Buschur
www.buschurracing.com
David Buschur
