IS it my transfer case????? vid inside
Old Dec 27, 2009 | 08:47 PM
  #61
fre's Avatar
fre
Originally Posted by R/TErnie
Fre,
do you have pictures of this? I think I understand what you're talking about. Ill have to pay close attention to it when I get it apart here soon.
Oh it's obvious, you pull the transfer case away from the tranny and you will see pretty little metal splines fall out hah. There are two tubes that run from the center diff inside the transmission to the transfer case, the outer one being for the rear and the inner one being for the front, the splines that stripped on mine were the inner or front one. The hollow shafts are very visible and easy to see defects on.
Old Dec 27, 2009 | 08:48 PM
  #62
R/TErnie's Avatar
fantastic. I can't wait to get my late Christmas present.
Old Dec 28, 2009 | 05:51 AM
  #63
StreetEvo's Avatar
The noise in your video sounds like the beginnings of a bad wheel bearing. But I have heard similar noises coming from differentials. I would jack the the car off the ground and let it idle in first while checking the hubs and rear diff for excess noise.
Old Dec 28, 2009 | 01:15 PM
  #64
danameisoj's Avatar
well the chassis ears determined that my transfer case has a majority of the frequency.
My wheel bearings are silent .. Not a wheel bearing .. Ill be searching for another tcase.
Old Jan 9, 2010 | 03:25 PM
  #65
R/TErnie's Avatar
any update on the diagnosis?
Old Jan 20, 2010 | 06:30 AM
  #66
danameisoj's Avatar
well ive officially stumped multiple technicians including myself and 2 driveline specialists.
transfer case was swapped out .. thats not it .
transmission was rebuilt and torn apart twice. all appears good inside.
axles were changed and driveshaft was changed.
Ive run out of things to check.
Old Jan 20, 2010 | 06:41 AM
  #67
fre's Avatar
fre
I would laugh my *** off if it is a wheel bearing. Those bastards must be pricey or a ***** to install for you to avoid it for so long. The wheel bearings are calling your name.... don't resist
Old Jan 20, 2010 | 06:53 AM
  #68
danameisoj's Avatar
not as expensive as a tranny and tcase . theyre like $200
i would welcome the wheel bearings right about now .. its a big joke for everyone at my shop right now.. everything that comes in with a car we automaticly call it a wheel bearing lol.
Old Jan 20, 2010 | 07:06 AM
  #69
Boltz.'s Avatar
FCOTM Winner
I didn't read the whole thread, but have you swapped out the entire clutch assembly? I imagine that would be the middle point of all of the abuse, after the pedal was popped back out and being the intermediate piece between matching the speed of the engine to the transmission.
Also, to everyone that says its a wheel bearing, I don't think thats the case. The noise would still be there if he put the clutch pedal in an Jerry also mentioned that it only makes the noise under cruise, if he had a bearing failure it would be making the noise as long as the car is rolling. I've been in a car with a bad wheel bearing like 4 times in the past year. They're usually very obvious.
Edit: Have you check the input and output shafts with a straight edge to see if they have actually been twisted? Are they pitted at all?
Double edit: GOOD LUCK!!
Old Jan 20, 2010 | 07:14 AM
  #70
Evoardo IX's Avatar
I just read the whole thread, and no one suggested to check engine/tranny mounts, just a thought. Also, clutch release bearing.
Good luck, keep us posted.
Old Jan 20, 2010 | 07:39 AM
  #71
danameisoj's Avatar
i actually started rolling the shafts around to see if they are still true last night . Ill take a straight edge to them today.
the pressure plate was inspected and all looked in order. The disc was swapped . but the clutch noise would vary on engine rpm rather then vehicle speed.
The mounts are all in order.
Old Jan 20, 2010 | 07:48 AM
  #72
danameisoj's Avatar
the other funny part of this is as jerry (94awdcoupe) mentioned last night and i agree 125% its a mechanical noise . It should leave a mechanical mark. all internal components of the drivetrain are spotless.
Old Jan 28, 2010 | 03:02 PM
  #73
danameisoj's Avatar
well for all of you that though it was a wheel bearing .. WRONG.. i changed out the wheel bearings and my noise is still there ..
ive had it with this thing .. the only part of my drivetrain thats still original is the transmission . and now im out of ideas
Old Jan 28, 2010 | 03:57 PM
  #74
R/TErnie's Avatar
buy a new evo! haha
rear diff... maybe the rear diff vibration is being transmitted back through the driveshaft and is causing noise from the T/C area.
Stiffer mounts on the diff/driveline/engine should make the vibration worse if my assumption is correct.
Besides..the diff is the last thing in the driveline!
Old Jan 28, 2010 | 05:42 PM
  #75
BluEVOIX's Avatar
I think R/TErnie has a good point about the rear diff causing the sound.
My car makes a less audible similar noise around 50+ mph when decel and very light throttle.
I've changed the clutch and changed out the transmission completely. I was pretty sure it was the t-case now but a couple of my friends are saying it also sounds like its coming from the rear and others say no.
You've changed out everything except the transmission. I have changed out the transmission so its safe to assume maybe it is the rear diff transferring the sound to the front.
Are you able to have access to try out another rear diff? I would change mine but lack of funds and also the sound being very faint keep me from changing it out right now.
