IS it my transfer case????? vid inside
Old Dec 8, 2009 | 05:28 PM
danameisoj's Avatar
Well I let a buddy drive my car .. and long story short he went to shift to third and ended up in first.. Locked up all 4 and saw over 9k in revs.
now ive got a hell of a noise coming from what i believe is the transfer case..
please chime in.
: also please dont turn this into a your an idiot for letting someone drive your car..
My friend is paying for all repairs. so im ok with things .. just a little bummed
heres the vids.
Old Dec 8, 2009 | 05:31 PM
ak47po's Avatar
Sounds more like a wheel bearing.
Old Dec 8, 2009 | 05:36 PM
fre's Avatar
fre
Yea sounds like a wheel bearing. Can you tell what corner it is comming from? Front, rear, right, left. Probably have a passenger go with you and try and see if they can tell.
Old Dec 8, 2009 | 05:42 PM
evo unknown's Avatar
Doesn't sound like TC. Sounds like something dealing with the wheel rotation. As you speed up the sound goes away.
Old Dec 8, 2009 | 05:44 PM
danameisoj's Avatar
no the sound is still there when its sped up .. the exhaust just drowns it out..
i highly doubt its a wheel bearing.
this happened directly after all 4 locked up.
Old Dec 8, 2009 | 05:46 PM
buchnerj's Avatar
I agree with all above, if it were the transfer case it would be more of a loud whine, and you would hear it increase in pitch with speed.
Edit: Can you narrow it down to a specific area of the car, or at least tell wether it is front or rear? Possibly rear differential, but like the transfer case I would expect that to increase in whine as the speed increased.
good luck
Old Dec 8, 2009 | 05:53 PM
Silver06evo9mr's Avatar
def the
Transfer Case Death Whine. Shep here you come... expect $$$ in repairs
Old Dec 8, 2009 | 05:57 PM
danameisoj's Avatar
i do all the labor and my friends paying for the parts ... so its not too bad.
im just going to have to throw the car in the air and stick it in gear see what happens.
Old Dec 8, 2009 | 06:00 PM
05evoGSR's Avatar
I dont think its the TC, every TC that i have seen go sounds more like a howl or old siren sound that is constant while at speed...never seen an intermittent sound come from a TC. Either way i would throw the car on a dyno and see if you can narrow down where the noise is coming from and take it from there. good luck
Old Dec 8, 2009 | 06:05 PM
beginning stages of the tcase prolly, or maybe its the trans.
does it shift fine?
Old Dec 8, 2009 | 06:07 PM
danameisoj's Avatar
shifts about the same as before...
every time i push the clutch in the noise goes away but then while i slow down its very faint.
Old Dec 8, 2009 | 06:08 PM
buchnerj's Avatar
I have heard a few transfer cases on their way out in these cars, and every time it is a solid whine, never intermittent like this case. I mean, yes, it is a possibility, but I doubt it with a noise like that. Maybe it is the beginning phase of it, but still, I don't think so.
+1 to the dyno and just cruise and see if you can narrow it down while outside the car. At least that will give you a solid answer as to where the noise is coming from.
Old Dec 8, 2009 | 06:11 PM
danameisoj's Avatar
Personally im thinking when it locked up it chipped a tooth in the transfer case and thats why i dont have a solid death whine.
Old Dec 8, 2009 | 06:16 PM
^ that. it will come if u drive on it enough. thats what happened to my car. except mine was done during a launch. then i drove on it for a few 1000 more miles and it slowly got worse to becomming a perminate whine.
Old Dec 8, 2009 | 06:18 PM
buchnerj's Avatar
First step is to see if you have any shavings or chunks in the fluid. Jack her up and drain it, if its black, or you see some solid little particles, then I suppose we have our answer.
