Max Boost on Stock Turbo
Old Dec 9, 2009 | 05:04 PM
ravnos04's Avatar
I was searching through the forums and couldn't find any answers. I am going speed density in the next week or two. I was wondering, with my mods, what the max boost the stock 8 turbo can handle.
I have a BR IC, BR ICP, BR TBE w/out Cat, WeaponR Intake. As far as I know, the exhaust manifold and other internals are all stock along with the ecu. Thanks.
Old Dec 9, 2009 | 05:48 PM
Stockie's Avatar
Would like to know the same thing... but for Evo9 stock turbo, mods: TBE no cat, 3inch front mount, injen pipes and injen intake
Old Dec 9, 2009 | 05:49 PM
JohnDoe1984's Avatar
What fuel you use will be a determining factor. Only on pump gas I would say near 25psi. That's just from what I've read on here. You'll start to knock after that unless you up the game with some meth, higher octane, or e85.
Old Dec 9, 2009 | 06:00 PM
ryno529's Avatar
I have seen the evo9 turbos in the rally cars spike 38psi and hold 32-34 but they only hold up for a few races. I have seen the 9 turbos at 28-29psi on pump gas for an on the edge street tune. As for the 8 turbo the most i have seen is 29-30 psi and for a pump gas tune 25-26 psi .
Old Dec 9, 2009 | 06:02 PM
BLKCarbonEVO's Avatar
This is if you have all supporting mods. A good FMIC is a must for a stock turbo because they blow so much hot air. It also really all depends on where your car stops making power.
Pump - 25-27psi (depends on 91,92,93 etc... and Also if your tuner likes timing or boost)
pump+meth - 30psi
E85 - 30-32psi
I ran a pump+meth setup to 35-38psi but I stopped making power around 30psi. I was just pulling up my tq curve. I would not spin it over 32psi because you will blow the turbo sky high. That's what I did, but I didn't care because I went with a Red.
Here is my 30psi vs. 35psi. As you can see I didn't make 1hp more going to 35psi. Just a **** ton of tq.
ravnos04's Avatar
ok, thnx for the feedback. I am running pump gas. My boost guage looks like it is at 22-23 psi. Once I am done with the SD conversion and all tuned up I will post up all the info.
Old Dec 10, 2009 | 04:44 PM
Stockie's Avatar
Good luck, very interested in your gains
Old Dec 14, 2009 | 06:00 PM
PaperClip's Avatar
My buddy has an evo 9 with stock turbo runnin 35lbs boost but he has alcohol injection and head studs
Old Dec 14, 2009 | 07:39 PM
Teal2nnr's Avatar
I've found that after 27psi my waste gate was having a hard time keeping up (this is with a Evo 9 turbo). I only run it at 22Psi daily, and 25-26 when i want to turn up the wick.....hopefully i won't have to suffer with the stock turbo for much longer haha
Old Dec 23, 2009 | 08:02 AM
Levar's Avatar
Veteran: Army
On E85, I'm tuned at 30PSI on the stock VIII with 9.8cm2.
Old Dec 23, 2009 | 08:21 AM
cij911's Avatar
On pump and in Colorado that is about as good as you'll get....You start @ 1 mile above sea level right and then if you go into the canyons / mountains can go as high as 1.5miles above sea level (hard for the little turbo)?
Old Dec 23, 2009 | 11:30 AM
4g63evoeight's Avatar
get a high pressure W/G acuator.
Old Dec 23, 2009 | 12:33 PM
importjake00's Avatar
I run 28psi daily on the stock IX turbo/pump gas.
Old Dec 23, 2009 | 01:24 PM
Stockie's Avatar
Really?!?
With which supporting mods? please list all...
Old Dec 23, 2009 | 02:09 PM
PlanoEvo's Avatar
On 93 i was able to get 28 spike on pump without much knock. i have tbe plus 4in ets core with a cop.
