Rear Diff problem
Old Dec 24, 2009 | 07:35 AM
Nasty Evolution's Avatar
Weird the EVO rear end is VERY stout. You must have been spinning the living crap out of one wheel some how. Or wrong fluid, or low on fluid. If you're finding teeth, you're diff is a ticking time bomb. Stop driving it, pull the cover off and inspect the ring and pinion. Prey TRE has parts for cheap because a new rear end is retared expensive. Even used you're looking at a grand or more.
Old Dec 24, 2009 | 07:50 AM
awdboosted's Avatar
This is very common with the Evo Diff. The oem clutch plates sucks.. I've seen a few Evo do this and the diff looses its locking abilities. We think it's happens from launching the car. I would get the TRE mod. Talk about a huge improvement and it’s so cheap to do.
Old Dec 24, 2009 | 10:08 AM
barneyb's Avatar
Just curious, what is the TRE mod - what gets changed?
Old Dec 24, 2009 | 11:00 AM
Stockie's Avatar
Originally Posted by barneyb
just curious, what is the tre mod - what gets changed?
+1
Old Dec 27, 2009 | 03:32 PM
awdboosted's Avatar
Check out the website.. It has all the info you need.
The adjustment of ring & pinion for high torque applications and all new friction plates is what make it so amazing.
TRE EVO DIFF
Old Dec 27, 2009 | 04:19 PM
barneyb's Avatar
Thanks!
Old May 23, 2022 | 02:42 AM
Emmi's Avatar
Hi, My rear JDM Evo9 diff with AYC is broke. Can I instal diffs from Evo7 or 8? What are the differences?
Its nit easy to find e9 diff. I found some from e7.
Old May 31, 2022 | 05:34 PM
EVOFans's Avatar
EVO 8 MR and onward have stronger/better rear diff for AYC
EVO 7 diff can bolt up but it should be weaker
Old Jun 1, 2022 | 12:22 PM
notrackback's Avatar
5 Year Member
If you are looking for an Evo VIII AYC Diff I have one from my JDM Evo VIII.
Has 112k kms on it, original not been replaced came with the car in 2003.
Runs and works no issues or hiccups, just replacing it with non ayc/non acd due to pushing 650+whp.
amsevokid
Feb 11, 2016 04:15 PM
doncarbone
Dec 10, 2014 07:48 PM
EvoJoeRacing
38
Aug 20, 2011 07:16 AM
revs10k
Midwest Region
Mar 14, 2011 12:54 PM
AoyamaJPN
Nov 22, 2010 01:28 AM
