Evo diff questions
Old Feb 7, 2016 | 04:27 PM
amsevokid's Avatar
Evo diff questions
Hey everyone I'm just a little confused about the front and rear diff. I have an evo 9 with acd so that means I have the ayc rear diff? I'm selling my acd xcase bc I want to buy a non acd xcase as well as a good rear diff. Now can I convert my rear diff to an Rs LSD rear diff? If I can then would I be able to keep the entire case and just swap the internals?
Old Feb 7, 2016 | 04:59 PM
kaj's Avatar
kaj
we have a mechanical LSD unit. with the plates arranged wrong, at that LOL.
Old Feb 8, 2016 | 09:50 AM
amsevokid's Avatar
Yeah I fixed that awhile ago, now I'm trying to me my evo a non acd evo 9, do I just get a non acd rear diff? Like an Rs LSD rear diff?
Old Feb 8, 2016 | 09:55 AM
kaj's Avatar
kaj
all the U.S. rear differentials are the same: mechanical LSD. ACD is in the transfer case and has nothing to do with it.
Old Feb 8, 2016 | 07:05 PM
amsevokid's Avatar
Yes but doesn't the acd xcase send fluid to the red diff? So I need a non acd diff
Old Feb 8, 2016 | 07:15 PM
kaj's Avatar
kaj
I give up.
Take the car to a reputable shop, tell them what you are wanting to do, and they'll make it happen.
Old Feb 8, 2016 | 07:51 PM
RS200's Avatar
AYC is what controls the rear diff, not ACD. Everywhere else, Evo 8/9 GSR/MR had AYC if it had ACD. Every Evo 9 in US (and worldwide?) has ACD without AYC, which means it is already JDM/USDM RS-spec, and therefore has a mechanical rear differential with no hydraulics. ACD is a god-send compared to the old viscous garbage. What are you trying to do?
Old Feb 8, 2016 | 08:01 PM
amsevokid's Avatar
Thumbs up
[QUOTE=kaj;11573726]I give up.
Take the car to a reputable shop, tell them what you are wanting to do, and they'll make it happen.[/QUOTEK
Old Feb 8, 2016 | 08:11 PM
amsevokid's Avatar
Thank you!! Finally
I'm trying to build a drag car. From what I have read on the forums previously people say keeping the acd is pointless and breaks easier than a non acd transfer case
Old Feb 8, 2016 | 08:21 PM
RS200's Avatar
Thank you!! Finally
It's cheaper to replace the non-ACD transfer case, probably the main benefit to the swap. The "RS" front helical LSD is what makes it attractive instead of the GSR's open front differential. Put a front LSD in any Evo 8 transfer case and you'll be fine.
Old Feb 8, 2016 | 08:26 PM
amsevokid's Avatar
It's cheaper to replace the non-AYC transfer case, probably the main benefit to the swap. The "RS" front helical LSD is what makes it attractive instead of the GSR's open front differential. Put a front LSD irn any Evo 8 transfer case and you'll be fine.
Ok so I can keep the rear diff I have and just get a evo 8 non acd xcase with the helical LSD. Now do they sell a kit to rebuild the rear diff to make that like new or stronger?
Thanks again u are helping me a lot
Old Feb 8, 2016 | 08:36 PM
RS200's Avatar
Yes, your rear LSD is the one to keep. TRE's MaxGrip rear LSD rebuild is a solid upgrade.
Old Feb 9, 2016 | 04:58 AM
Terror Rising's Avatar
You are going to have a rough adventure building that drag car if you don't learn to use the search function and do your own research before asking questions. A couple good threads to get you started:
https://www.evolutionm.net/forums/ev...oking-evo.html
https://www.evolutionm.net/forums/ev...ound-here.html
Old Feb 10, 2016 | 10:23 PM
amsevokid's Avatar
Really? Because last time I checked asking a few questions about the same part isn't "not using the search function". I've done plenty of research and that's exactly how I learned how to take my engine, tranny, suspension, basically everything out of my car. This was the only thing I needed help with and sorry if I'm using this forum for what it's for, helping fellow evo owners. With that said I would appreciate it if you would keep your opinions out of this thread.
Old Feb 10, 2016 | 10:24 PM
amsevokid's Avatar
Thanks again for the help, it seems nowadays people would rather give attitudes than advice.
