stupid of me to try .010" oversize bearings?
Subscribe
Dec 14, 2009 | 12:02 PM
Well title says it.. Is it silly of me to try and run 010" size of main/rod bearings? And run on oversize ACL bearings
has any one experiance of this?
Reply 0
Dec 14, 2009 | 01:17 PM
Why are you wanting to do this?
Reply 0
Dec 14, 2009 | 03:51 PM
its not something i want it a qeustion to save my motor..
Reply 0
Dec 14, 2009 | 04:16 PM
as long as the block is machined for the oversized bearings, and you check and double check the tolerance, it will work. definately don't just drop oversized bearings in there without machining. most likely the motor wont even turn over if you do.
Reply 0
Dec 15, 2009 | 06:26 AM
You cannot just put in 10/10 bearings, buddy. What's going on with the motor? Why are you thinking that this is a solution? Let's see if we can't help diagnose your issue and come to a resolution.
Reply 0
Dec 15, 2009 | 06:31 AM
does your crank need to be cut or something why you need oversized bearings?trust me you are better off buying a new crank/or a good used one than going that route,you will pay the price later....
Reply 0
Dec 15, 2009 | 06:52 AM
Definitely don't just throw them in there and think you are good to go. If you spun a bearing or something it is best to take the engine apart and do it the right way. Good luck.
Aaron
Reply 0
Dec 15, 2009 | 08:36 AM
Are you so ignorant that you think .010 bearings are some sort of upgrade over standard bearings? The only reason you should need oversised bearings is because you damaged your crankshaft and it needed to be cut. The oversized bearings compensate for the metal that was removed from the crankshaft.
I'm still laughing as to whether this thread is serious or not.
Reply 0
Dec 15, 2009 | 08:53 AM
come on dude, that's a little harsh. the guys is asking a valid question. I hope he does post what his issue is so that we can try to help him figure it out.
Reply 0
Dec 15, 2009 | 08:56 AM
^+100000 Whats the reason for this??????
Reply 0
Dec 15, 2009 | 09:01 AM
Quote: Are you so ignorant that you think .010 bearings are some sort of upgrade over standard bearings? The only reason you should need oversised bearings is because you damaged your crankshaft and it needed to be cut. The oversized bearings compensate for the metal that was removed from the crankshaft.
Wow... I can't believe that the question post by the OP elicited a response like this.
Reply 0
Dec 15, 2009 | 09:04 AM
The reason is that he probably spun a bearing, ruined his rods ( and or crank), wants to try and reuse them by machining them and putting in larger rod bearings to take up the space of the material removed.
As long as you can trust the machine shop, go for it.
Scorke
Reply 0
Dec 15, 2009 | 11:14 AM
Quote: The reason is that he probably spun a bearing, ruined his rods ( and or crank), wants to try and reuse them by machining them and putting in larger rod bearings to take up the space of the material removed.
Scorke
I spun a rod bearing on cyl 4 thats why im askin.. it will save me few hundred dollars to repair here at home ... becouse i can cut it here...
otherways i have to go and buy a new crank in the U.S + shipping and toll price.. thats why im askin if this is stupid of me to do..
im sure i have to go anyway the expensive way
Reply 0
Dec 15, 2009 | 11:15 AM
im not an idiot..
Reply 0
Dec 15, 2009 | 11:36 AM
Quote: I spun a rod bearing on cyl 4 thats why im askin.. it will save me few hundred dollars to repair here at home ... becouse i can cut it here...
ok. What you want to do is have it checked and measured at a machine shop. If it can be turned and refinished properly, you can prep it for 10/10 bearings. You can sometimes get it polished and be just fine. If not, you'll need a new crank shaft.
How bad is the journal? Any pics? How long did it run with the spun bearing?
Reply 0
