02 Eliminator downpipe vs 02 dump
Old Dec 29, 2009 | 07:49 PM
Nomad4g63's Avatar
What is the difference between
MAP Stainless Steel 38mm MVS O2 Eliminator Downpipe
and
A regular 02 dump
I mean stating the obvious u get rid of the internal wastegate, but NOISE wise, and performance WISE any different?
Old Dec 29, 2009 | 07:53 PM
Kracka's Avatar
They'll both sound the same but the o2 elim dp has the performance advantage with lower weight, less chance of exhaust leaks, and less turbulence with the disadvantage being a more time consuming install.
Old Dec 29, 2009 | 07:54 PM
URBANRCR's Avatar
MAP's downpipe is a full 3" most o2 dumps are not.
The noise level should be the same with both.
You may see a small power difference with the MAP o2 elim DP vs other o2 dumps.
