MAF Issue
Old Dec 31, 2009 | 07:16 PM
neodestroyer's Avatar
MAF Issue
Hey guys i've been having an big issue with my car running around 11 afr at idle. I've been troubleshooting this problem for about the last month or so and have narrowed it down to my mass air sensor isnt getting enough voltage and its throwing the readings off. I dont really know where to start looking at. Any idea's guys?
Old Dec 31, 2009 | 07:22 PM
alicea8541's Avatar
Easiest way to do this is borrow a buddies MAF and ride around with it. You will know pretty quick if it is your MAF that is bad. Had to deal with this myself a few months ago.
Old Dec 31, 2009 | 08:16 PM
Well you see I have already done that and I'm still pulling the same CEL code for the MAF not getting enough voltage.
Old Dec 31, 2009 | 08:26 PM
alicea8541's Avatar
I'm assuming it is a P0101. If so take a look at this link. Bad thing about this code is there are a lot of different things that can cause it.
http://www.obd-codes.com/p0101
Old Dec 31, 2009 | 09:37 PM
Gary@MellonRacing's Avatar
check ur o2 sensor sir
