Ss Clutch Line
Old Jan 5, 2010 | 01:02 PM
Brsox10288's Avatar
Ss Clutch Line
About to order a new ss clutch line to replace this crappy rubber one, im looking at the ams clutch line and the Speed-Source one... anybody have experience with other lines or these?
Old Jan 5, 2010 | 01:26 PM
MR Turco's Avatar
i have the russell one. The install is terrible and honestly, i didn't notice a difference. I would recommend removing the clutch pill in lieu of the clutch line. That was a bigger, and better, difference in clutch response and feel.
Old Jan 5, 2010 | 01:31 PM
Kracka's Avatar
I've had really good experiences with Speed-Source products. I also like TechnaFit for their SS lines. I do agree with MR Turco above though.
Old Jan 5, 2010 | 03:05 PM
MICLOIV's Avatar
i just ordered the AMS line and will be installing it along with a new clutch this weekend so well see how she works out
Old Jan 5, 2010 | 03:51 PM
thedru13's Avatar
I have a WORKS SS clutch line. I agree with everyone else. This install Was AWFUL... Make sure you have someone with you that has small hands. Thank god for my girlfriend.. And for the fact she is a better mechanic than me. She was able to fit her hand in that god awful spot. also make sure you route the cable correctly test fit the battery tray. I made this mistake and was a royal pain in the A$$.. and I double the point to remove the restricter pill.. Also upgrade your shift linkage bushings if you have not while you are in there. Good luck.
Old Jan 5, 2010 | 04:18 PM
Kevin.'s Avatar
I have the Speed Source one next to me waiting to go on. Dreading the install but oh well.
Old Jan 5, 2010 | 07:31 PM
Brsox10288's Avatar
Where's the pill located and nobody really has recommended anything yet :P
Old Jan 5, 2010 | 07:35 PM
Kracka's Avatar
Its inside the clutch slave cylinder. Remove the bleeder nipple and the fluid line from the slave and poke out the little plastic pill with a small allen wrench.
Old Jan 6, 2010 | 06:41 AM
thedru13's Avatar
I have my WORKS SS Line as stated... I recommend it. Better? I think with this Its more about the install than the SS line. they are all pretty much the same.
Old Jan 6, 2010 | 10:03 AM
Brsox10288's Avatar
Gotcha, isnt there two different lines that can be changed for the clutch lines? I know the one that runs to the master cylinder is one of them (could someone list a link to one) and the other one which im not really sure where to find it
Old Jan 6, 2010 | 10:04 AM
Kracka's Avatar
http://www.amsperformance.com/cart/M...rivetrain.html
AMS sells both the upper and lower lines.
Old Jan 6, 2010 | 10:51 AM
Brsox10288's Avatar
and also is there a how to somewhere for these?
Old Jan 6, 2010 | 11:26 AM
thedru13's Avatar
http://www.evomoto.com/tech_articles...h_article_id=4
Oh and make sure you have extra fluid to bleed the clutch if you don't use a speed bleeder. Took me a few tries....
Old Jan 6, 2010 | 11:30 AM
Brsox10288's Avatar
I actually found a clutch line that replaces the whole clutch line without spending double the money on getting two seperate lines. It is made by alamo motor sports.
Old Jan 6, 2010 | 12:54 PM
Kracka's Avatar
Price? Link?
