Anyone running a kelford 272/280 combo on a viii?
I'm looking to pick up some top end and wondering if anyone has had any luck with this combo? Any helpful insight would be appreciated. Tia
I know james reese on the socal boards ran kelford 280/280's & switched to 272/272's on his evo8.....not exactly what you were asking about....the top end was better with the kelford 280's, mid-range was a lot better with the kelford 272's.....
1wkdevo on socal ran a staggered kelford cam set-up...it was a give to get situation as well.
what are your goals with the car? only running on e85?
GL
GL
Steve: If I am not mistaken, you are already running a Kelford 272i/272e cam setup, right? So, you would only need to swap out the exhaust camshaft. Is the cylinderhead p&p´ed as well?
As is, you are putting out pretty good power with your present setup(E-85, right?). So, exactly how much more power are you hoping to gain? Have you thought of tuning with adjustable cam gears to maximize topend power?
If the BBK-Full is not quite fulfilling your topend power needs, why not wait until CBRD releases the upcoming BBK-XL(?)? The new turbo is supposed to have improved topend capabilities? You should be able to just send in your present turbo for an upgrade conversion.
I know james reese on the socal boards ran kelford 280/280's & switched to 272/272's on his evo8.....not exactly what you were asking about, but top end was enhanced, but the low end was sacrificed a lot.....
GL
GL
Or was that just a typo?
Yeah I'm currently running the kelford 272's and just looking to change the exhaust cam. As for the turbo I will also be converting to the bigger bbk as soon as Chad offers it. The goal is simply to make the car faster in a straight line both drag racing and from a roll. And yes e85 all the time.
sorry for the confusion.
