wastegate actuator end piece?
Where can i get the end of the wastegate actuator, the piece that twists onto the rod of the wastegate actuator and connects it to the wastegate flapper. Thanks
is this for a stock WGA? and are you just looking for the screw on female portion with eyelit? Im sure you can just go in the WTB section and ask anyone for a stock actuator and take it off. It would also matter if you want an 8 or 9 actuator. I think the 9 is longer than the 8's... GL
sounds pretty easy to just pick up some stock WGA's.. folks on here would probably get rid of them for next to nothing... Not trying to sell you anything, but I've got two just gaining dust, and I'm sure there are others in your local area with the same... Good luck, hope it works out..
