Is the exhaust still so black after SAFC?
Old Oct 28, 2003 | 08:20 AM
lynkz's Avatar
I have a SAFCII and I'm just waiting on my harness to arrive before installing it. I also have BR Stage 1 installed, and have noticed the with the free flow exhaust on, I can really notice the blackness on the tailpipe and some around the bumper, which I expected to have happen. With the SAFC on the car and therefor the car running more lean I assuming (hoping) that the blackness will not be as evident, or at least much less. So anyone w/ exhaust and SAFC let me know what your results from this are. Thanks.
Old Oct 28, 2003 | 08:46 AM
lynkz's Avatar
bump.
Old Oct 28, 2003 | 08:55 AM
sccavee's Avatar
If you lean the car out the black will be less. The coloration will lighten up and bunch and will become more gray then black.
Old Oct 28, 2003 | 09:05 AM
cecilia's Avatar
but aren't turbo's supposed to run rich?? because thats what i was told....
Old Oct 28, 2003 | 09:07 AM
cecilia's Avatar
also when i get my SAFCII the numbers for tunning are those accurate?? the numbers that have been posted??
Old Oct 28, 2003 | 09:13 AM
Quickshift's Avatar
I have notice less well alot less black crap on the tail pipe. I am running buschars mods and it kicks ***.
Old Oct 28, 2003 | 09:37 AM
Hammerli's Avatar
As has been posted many times, there is a lot of variation in Evos. Using someone elses numbers without any form of monitoring is not a good idea. If you don't have access to a dyno, get a wideband and EGT, and start rich then make gradual changes.
Old Oct 28, 2003 | 12:32 PM
zTargeTz's Avatar
ive got an EGT gage, but no wideband 02 sensor.. can i still tune it or do i need both?
Old Oct 28, 2003 | 12:42 PM
ItsStockOfficer's Avatar
wideband is unnessecary, just use the egt, start with the richest reasonable numbers, say if some people are -6 and some -12, start with -6....then aim for 880c at redline in 3rd.
Sean
Old Nov 3, 2003 | 10:59 PM
boostedwrx's Avatar
Then you can start doing something good for your car like monitoring the ignition timing and watching out for knock. Get a pocketlogger and be on your way
Kasper
Feb 25, 2015 04:01 AM
evo ippo
Feb 5, 2007 12:44 PM
QwikEVO
Jul 2, 2006 02:35 AM
Warrtalon
11
Apr 20, 2005 10:30 AM
NocturnalEVO
13
Dec 14, 2004 11:10 AM
