New revised QuarterMaster clutch months away!
Old Feb 21, 2010, 03:43 PM
  #31
R/TErnie's Avatar
bump for information?
Old Feb 27, 2010, 10:23 PM
  #32
R/TErnie's Avatar
I called.... Evidently they don't work on the weekends. Still waiting for information
Old Feb 28, 2010, 08:55 AM
  #33
SoloEvo's Avatar
Looking forward to updates on this
Old Feb 28, 2010, 09:33 AM
  #34
Owens Racing's Avatar
I decided to go with the original tried and true unit.
Hoping this new one crosses the bridge better from street to race.
Old Mar 11, 2010, 10:09 AM
  #35
R/TErnie's Avatar
I called QM yesterday and spoke with one of the tech's...
The redesign will consist of TWO main improvements....
-New designed cover (lighter and possibly more stiff?)
-Option of running a chromoly flywheel (heavier) or an aluminum flywheel with steel insert (lighter)
the idea of makign a heavy flywheel is that it improves the streetability of the clutch. I don't know that the current cover is deflecting or why they decided they needed to make the cover lighter...it was not explained.
The ETA I was given over the phone was 1-2 months from March 10th (When I called) This should work out very well with my schedule. I'll opt for the heavy flywheel.
Old Mar 11, 2010, 10:19 AM
  #36
4G63W8's Avatar
Originally Posted by ChrisCarey
I'm not sure exactly what information I can share as of yet, but some exciting stuff is in the works As a whole QM is looking to increase market share in what they called the "street performance market." Clutches will focus on driveability as well as power capacity, and yes they currently have a stock driveshaft that we supplied them to develop an aftermarket driveshaft
Hey Chris,
which one is mine buddy,the new or the old style, i would reckon the old style with your (map) flywheel?
Marios. (Cyprus)
Old Mar 11, 2010, 05:42 PM
  #37
PATRICK B.'s Avatar
Subc'd very interested in how things turn out
Thanks for investigating and posting up Ernie
Howvere from the sound of it it doesn't seem to me that it will help the streetability all that much especially if the stiffer fingers will equate to harder pedal pressure as i'd find even more of a pain to slip from a dead stop.
Only way i see it becoming more streetable is by absorbing the shock from initial engagement but not sure how they address that w/o putting springs in the disc but at that point you're probably better off w/ an Exedy
If it really does help i'd be very interested to see if i could upgrade my original unit but i won't hold my breath
Old Mar 11, 2010, 05:56 PM
  #38
theLAM's Avatar
I hope i can send in my old unit for a 50% discount or something when it comes out
Old Mar 11, 2010, 06:32 PM
  #39
R/TErnie's Avatar
The didn't say they were making the diaphragm fingers more stiff... They said they were making the cover more stiff. I think that means that the actual cover that holds the diaphragm fingers will deflect less while the fingers are stressed. Giving you better feel.
Old Mar 11, 2010, 06:38 PM
  #40
05ah8james's Avatar
I just bought one of these. Excited to install it!
Old Mar 11, 2010, 06:40 PM
  #41
05ah8james's Avatar
^^ Not the new one...
Old Mar 24, 2010, 11:45 AM
  #42
blackgsx01's Avatar
http://www.dsmtuners.com/forums/driv...twin-disk.html
I found this while searching dsmtuners. I assume this is what the clutch will look like.
Old Mar 24, 2010, 04:45 PM
  #43
bostonhatcher's Avatar
If anything is gonna break, it's going to be the rivets holding the hub to this disk:
Old Mar 24, 2010, 05:28 PM
  #44
EvoFlash's Avatar
those were last year ^^^.
Old May 15, 2010, 10:26 AM
  #45
DBallz's Avatar
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Bump for any new updates in the market for a multiple disk kit. QM and possible Exedy Triple
Quick Reply: New revised QuarterMaster clutch months away!
