help plz
Old Jan 11, 2010 | 10:23 AM
haseeb's Avatar
help plz
Hey I started my car yesterday after 2 weeks ,its like freezing cold in here ,
The car started fine yesterday after 2 weeks ,I dint drove the car yesterday but I let
It idle for 10 mins and than shut it off .
Today when I tried to start the car its not starting ..
Plz help me where the problem cud be ..
Cud it be fould plugs ?
Old Jan 11, 2010 | 10:30 AM
thedru13's Avatar
did you check to see if the battery is bad? Have the battery checked may be bad..
Old Jan 11, 2010 | 10:45 AM
haseeb's Avatar
I've jumped it with another in car battery but still not starting
Old Jan 11, 2010 | 10:46 AM
thedru13's Avatar
A bad battery may not work. i would try another battery or have yours tested. That is where I would start first..
Old Jan 11, 2010 | 10:58 AM
holiday63's Avatar
i didnt realize it got so cold in pakistan.
anyway, start simple by checking the battery and check the plugs.
are you running on e85 or gasoline?
stock ecu or standalone?
Old Jan 11, 2010 | 11:01 AM
haseeb's Avatar
Apexi power fc is wat I'm running ..
No e 85 its 93 octane ...
Old Jan 11, 2010 | 11:24 AM
Dragking2189's Avatar
I just had the same problem with my car, check the battery to see if it's any good. I doubt the battery is fried is more likely to be dead. Get the battery charged up and try to start the car, Also check the fuses that are on the positive terminal mines were fried so the alternators charge was not reaching the battery basically the car will idle for 20 minutes and I would shut it off and then when i wanted to start it wouldn't start at all. batterys dont like cold weather .
