How to Remove Injector Resistor
I need to know whats the best way or easy way to remove the resistor to run 2000cc injectors. Does anybody have a diagram or something on how to?
Thanks
Thanks
Cut all 5 wires, connect them all together and plug it back in. It is pretty striaght forward.
I beleive the connector is the same as the 1G and 2G resistor box too, incase you don't want to cut up your evo resistor.
If you want something a little nicer, you can try to find the pins. I contacted Balenger Motorsports since they have a lot of Sumitumo connectors, they were not able to get the pins for me though. Mostly because I was only interested in buying 10 or so pins, I would imagine.
I took a bunch of pictures of how to do it, although it is really straight forward.
If I can get some free time I will post some up.
All wires go together, thats it very simple.
Mitch
Mitch
https://www.evolutionm.net/forums/ev...istor-box.html
If you search in the "how to section" it was the first one i got.
Here is the FSM diagram in this post and a few pics of the injector resistor pack a few posts further down:
https://www.evolutionm.net/forums/ae...ml#post6731648
Its located on the passenger side of the firewall back behind some relay. Its relatively easy to access. As 03whitegsr said, once you have the resistor pack with the plug removed, cut the resistor pack from the plug, solder and/or crimp all five wires together, and then insulate. Reinsert plug into vehicle harness, and you're done.
[WTB] Injector resistor pack
3gevoclipse
Sep 21, 2016 01:47 PM
popadel
Jul 22, 2007 11:30 PM
