Please read!! Failed QuarterMaster Twin Disk. Literally getting VERY PISSED!!!
Old Jan 18, 2010 | 01:58 PM
evolution253's Avatar
Please delete. Problem resolved.
Problem has been resolved. Thanks for everyone's input and help.
Old Jan 18, 2010 | 02:01 PM
akauf's Avatar
pics aren't working.
edit: Yeah that tob toasted your pp fingers
BenJ's Avatar
pictures do not work.
Old Jan 18, 2010 | 02:03 PM
Sorry. It should work now.
Old Jan 18, 2010 | 02:05 PM
SpooksEvo's Avatar
Wow man, you have luck like I do. If there is .01%defect rate I seem to be the one with it. Hope you get everything back up and running soon. It will make you feel a lot better once it is all behind ya.
Good luck
Old Jan 18, 2010 | 02:08 PM
Thanks man. I just hope everything all just works out. I got the fattest headache because of this car....
Old Jan 18, 2010 | 02:10 PM
reactionevo8's Avatar
it looks like the clutch pedal stop either wasnt there or wasnt adjusted properly...looks like you had binding from overcompressing the Diaphragm...im guessing installer error...sorry
Old Jan 18, 2010 | 02:14 PM
Clutch pedal stop? Can you explain how it's adjusted?
Old Jan 18, 2010 | 02:18 PM
taken directly from their website hydro tob install manual
PEDAL STOP:
· Install a pedal stop to prevent over-stroking the clutch.
· The best place for a pedal stop is at the pedal face.
1. Install a rigid pedal stop to allow near full stroke of the pedal.
2. Slowly apply pressure to the pedal while applying a torque to the clutch, typically by trying to rotate the driveshaft.
3. Set the pedal stop near the point where the release is felt.
4. Adjust the pedal stop to allow approximately 1/4” more of pedal travel at the pedal face past the initial release point.
EDIT..i see you are from wa,who did the install?
Old Jan 18, 2010 | 02:23 PM
Thanks. I'm gonna show this to the shop too.
Old Jan 18, 2010 | 03:29 PM
94AWDcoupe's Avatar
this is 100% correct.
Old Jan 18, 2010 | 04:04 PM
MOREPSiTEHBETT4's Avatar
yah, I havent seen a clutch like that ever, which probably means installer error
Old Jan 18, 2010 | 06:25 PM
SPECJUNK's Avatar
is your input shaft leaking horribly????
and this is nothing to the carnage ive experienced with other clutch manufacturers.
Old Jan 18, 2010 | 07:46 PM
I didn't see anything leak. But I did see smoke coming out my hood when all this was happening. Lol. What happened with your clutch?
Old Jan 18, 2010 | 07:52 PM
Teal2nnr's Avatar
**** sorry to hear that, post up what happens
