BC 2.6 Stroker Engine
Old Jan 18, 2010 | 05:07 PM
young gun's Avatar
Hey Guys,
Trying to search for more information on this setup, however finding it difficult to find many guys who have it done.
Is it worth going to a 2.6 over a forged 4G64?
And has anyone had any difficulties with the BC 2.6 Stroker setups at all?....
Old Jan 18, 2010 | 06:51 PM
NitrousOxide's Avatar
Wow, this is the first time to hear about a 2.6 on an Evo engine.. That would be CRAZY :P
It will be as capable as a skyline engine!!!
Bump for this thread!
Old Jan 18, 2010 | 07:01 PM
Talonmotosports's Avatar
i am looking for info on this engine build too. Seems really interesting
Old Jan 18, 2010 | 07:13 PM
Wickedwhite8's Avatar
minus 2 cylinders
Old Jan 18, 2010 | 07:27 PM
[I.R.A.]_FBi's Avatar
stroked 4G64
Old Jan 18, 2010 | 07:32 PM
gsrboi80's Avatar
I believe Paul Nelson had issue after issue with that engine set up in his race car.
Search BC 2.6 and you should find the info.
I believe there is a older Evo overseas running the kit without issues though
Old Jan 18, 2010 | 07:35 PM
https://www.evolutionm.net/forums/ev...l-stroker.html
Old Jan 18, 2010 | 08:06 PM
JohnBradley's Avatar
I will say pass.
Old Jan 18, 2010 | 09:12 PM
whitegalant's Avatar
This is the first time I've heard about a 2.6l that would be pretty nuts
Old Jan 18, 2010 | 09:16 PM
Svendiesel's Avatar
The idea sounds cool, how well it would really work out though is another. Thatd be sick as hell though if it worked out just as well as a 2.3 or a 2.4 does haha.
Old Jan 18, 2010 | 10:30 PM
project_skyline's Avatar
Wasn't GSC making a 2.6 stroker kit because BC sucks?
Old Jan 19, 2010 | 09:55 AM
Chronic Evo's Avatar
Check out this thread on the mlr about a guy in Sweden that's running a 2.6 on his 6.
http://lancerregister.com/showthread...&highlight=2.6
Old Jan 19, 2010 | 10:08 AM
APM Racing's Avatar
150mm rod 108mm stroke?? 1.415 rod ratio? or are they using a longer rod with a moved up wrist pin? I think that would be impossible. Piston speeds would be incredibly high. I would think you would have to keep this thing around 7500 rpm max. The 100mm stroke and 150mm rod (4g64,4g63 2.3) already has enough RPM issues. I personally have an aluminum rod 4g63 with a 100mm crank that is knife edged and i get worried past 8000rpm.
Old Jan 19, 2010 | 12:42 PM
evo_glasses's Avatar
Wow... Interesting... According to his dyno charts it looks like Mr. Alex doesn't run past 6500 RPM's... But then again... Does he need to... hahaha...
Old Jan 19, 2010 | 06:05 PM
The 2.5s and 2.6s have kicked rods out only running to 6500. Again I will say pass.
