Dry nitrous setup
Old Jan 19, 2010 | 01:20 AM
bsh's Avatar
bsh
Dry nitrous setup
Hi
I have ordered a Driven Innovation intake with 4 bungs for nitrous for my Evo 2. I will use a dry setup there the Vi-PEC will control the extra fuel using my excisting injectors. I will go for a max 100 hp shot.
Are there any specific brand I should go for regarding solenoid, nozzles etc?
What do you guys recommend?
Thanks
Ben Stian
Old Jan 19, 2010 | 01:43 PM
evokid511's Avatar
why not a wet shot wayyyyy safer?
amd i ran an NOS setup and loved it
Old Jan 20, 2010 | 05:21 AM
bsh's Avatar
bsh
Why is it a lot safer?
Thanks
Old Jan 20, 2010 | 10:17 AM
[I.R.A.]_FBi's Avatar
The ECU is controllign it and adding fuel thru the usual injectors so it'll work out the same, no?
Old Jan 20, 2010 | 10:33 AM
evokid511's Avatar
ive just always heard that a wet shot is much safer because the added fuel from the fuel solenoid... im not sure how the ecu would compensate itself but im no expert at all when it cocmes to that, ive just always run the wet shot to be safe
Old Jan 20, 2010 | 02:06 PM
Stockie's Avatar
Thanks
Wet shot is a lot safer, because if your ecu doesnt detact the temperatures correctly, it will just make you run RICH as hell, dry shot on the other hand will rip your heads off.
Old Jan 20, 2010 | 05:20 PM
FX11's Avatar
wet shot ftw
Old Jan 20, 2010 | 05:27 PM
gt30revolXmr's Avatar
ive also heard running a wet shot is a lot safer thats why i run a wet 75 shot. as far as comparing different brands ive had a NOS (Nitrous Oxide Systems) kit and NX (Nitrous Express) kit and i liked the NOS kit better because i had some problems with the NX silenoids getting stuck open
Old Jan 20, 2010 | 05:29 PM
stuck open?
Old Jan 20, 2010 | 08:34 PM
Joshs EVO's Avatar
Must have been a sweet ride
Old Jan 20, 2010 | 11:24 PM
bsh's Avatar
bsh
And if the fuel solenoid doesnt open?
Old Jan 21, 2010 | 12:43 PM
RevMoto's Avatar
Even a wet shot is for pussies. Direct port injection is the way to go.
Time to nut up or shut up!
Old Jan 21, 2010 | 12:53 PM
borievoinitialD's Avatar
http://www.youtube.com/watch?v=0FZFa...eature=related
that will resolve any questions you have...
Old Jan 21, 2010 | 02:41 PM
evokid511's Avatar
wowww
Old Jan 21, 2010 | 02:47 PM
reactionevo8's Avatar
lol,that is a wet shot you have pictured
