Stronger Transfer Gears?
Old Jan 19, 2010 | 01:36 AM
Erikos's Avatar
Question Stronger Transfer Gears?
I have been searching and all I have found is transfer case rebuilds with stock gears and some "Tweaks" to help the transfer gears live. Are there any stronger aftermarket transfer gears out there?? thanks
Old Jan 19, 2010 | 12:52 PM
94AWDcoupe's Avatar
none exist.
Old Jan 19, 2010 | 02:06 PM
Chele's Avatar
None. I had Dog Box Racing do my rebuild a while back. The gears were cryo'd and coated. I forget the name of the coating, I'm sure someone can chime in with it. Haven't had any issues since.
Old Jan 20, 2010 | 08:01 PM
EVODreams's Avatar
I have wondered this as well. I know people have went 8's on the stock ones, but I would look at it more for getting better duribility for everyday driving. and figure out how to keep it from leaking out of the transfercase as well!
Old Jan 21, 2010 | 10:04 PM
Erikos's Avatar
Interesting, seems like someone would have made some, seeing as these are an Achilles Heel.... Thanks for the info.
Old Jan 29, 2010 | 10:54 AM
Erikos's Avatar
Trying to work with a company to have these things made, I think it may be a good solution.
Old Jan 29, 2010 | 01:42 PM
dieselmd's Avatar
Sir, before you spend any money, email the tranny and transfer case builders on this forum. If I remember correctly, and I stand to be corrected, the gears in the T-case may be too hard. That's one of the reasons for them breaking.
Old Jan 29, 2010 | 01:55 PM
SloRice's Avatar
Probably just need a better driver....
Old Jan 29, 2010 | 02:02 PM
Erikos's Avatar
Too hard for what? They are brittle? Stronger gears would solve that
Old Jan 29, 2010 | 02:07 PM
Chele's Avatar
The gears are very hard. Isn't the problem with the ring and pinion clearance? I thought you could shim it out a bit and viola, done. No?
Old Jan 30, 2010 | 08:49 AM
94AWDcoupe's Avatar
The problem with t-case is it is the definition of hypoid gear drive. And the ring gear drives the pinion instead of the more leverage friendly pinion driving the ring gear. There is tremendous Sliding pressure on face of gears.
"Hypoid" is not really a question of oil, so much as a question of
gearcutting. Old (1920's) rear axles used straight bevel gears to form
the crownwheel and pinion. These had two disadvantage, the pinion
shaft meets the crownwheel on its central axis, and the straight cut
gears are noisy. By using a more complex "hypoid" gear tooth shape (if
you look at a pinion, the teeth appear twisted) these problems can be
addressed. The more gradual engagement of the teeth along their length
reduces noise. By careful design of the geometry the pinion can be
made to mesh _below_ the axis of the crownwheel. As the centre height
of the crownwheel is fixed by the wheel height, this allows the
propshaft to be lowered relative to the car body, giving a clearer
floorpan and lower centre of gravity for better cornering. Hypoid
bevels are now universal in this application.
Because of the sliding contact that hypoid gears make, their
hydrodynamic contact pressure is higher. To be suitable for use with
hypoid gears, a lubricant must be capable of resisting high pressures.
Oils with "EP" ratings (Extreme Pressure) such as EP90 are required.
Some brands describe themselves as "hypoid" instead, a term which is
synonymous with EP. GL-5 is a formal API standard for this type of oil
Old Feb 1, 2010 | 03:18 PM
Erikos's Avatar
So stronger gears would be good
Old Feb 1, 2010 | 04:22 PM
czilla's Avatar
Shep transfercases are the best
Old Feb 1, 2010 | 07:21 PM
Mako3's Avatar
I was curious as how strong the stock evo ix mr tranny is? At what time in HP is a change needed? Ive heard great things about shep and ppg
Old Feb 1, 2010 | 07:28 PM
AngryEvo8's Avatar
REM process when you rebuild ftw!!
