Air temp v.s. Air flow
What's going to make me more power? Colder air sourced outside the engine with a longer intake tube, or warmer air sourced inside the engine bay with a shorter intake with less restriction?
I will agree with what has been said so far, but it all depends. What temp differences and what pressure differences? If you know those numbers, you can calculate it yourself.
I remember doing some calculations a while back and came up with about 25* increase in IAT was about equal to a 1psi pressure drop. Here's a post from a while back where I did a back to back test of the stock airbox and open filter. This is a good comparison of pressure drop vs temp comparison.
But, like I said it all matters how much pressure drop you are adding with the longer pipe compared to how much cooler temps you are getting. If my math was right when I was calculating it go with the 25*F per 1psi as an equal tradeoff.
