Head gasket replacment.
Old Jan 30, 2010 | 02:53 AM
hussein's Avatar
Originally Posted by MasterNater
You can ziptie the timing belt to each cam gear. Remove the cam gears from each camshaft, and move them out of the way. Then, you can pull the head without completely removing the timing belt.
as above
Old Jan 30, 2010 | 08:00 AM
barneyb's Avatar
If you chose to use the Zip tie method, have a mark on the crank sprocket and onto the belt. The belt does like to jump a tooth at the crank sprocket.
Old Feb 1, 2010 | 12:40 PM
rickyart23's Avatar
Is there a step by step guide on how to do this i have the basic knowledge ive done cams but something with pictures would b nice
EVO 4 life
Jun 29, 2016 08:28 PM
pips
11
Apr 9, 2014 06:09 PM
moevo9
21
Mar 15, 2010 10:58 AM
mandy1
Nov 23, 2008 08:37 PM
SeanC
Oct 20, 2008 05:14 PM
