9 turbo in an 8
Old Jan 27, 2010 | 04:17 PM
tristat3's Avatar
one of the studs broke off when i was removing my stock turbo
they are very likely to brake off if not lubricated well (soaked)
Old Jan 27, 2010 | 05:20 PM
silver05evo8's Avatar
thanks for the heads up. i bought my car used with 40,000 miles on it last year and only put 3,000 on it since then. It was "stock" but prolly had an upgraded turbo on it at some point. hopefully they come off as easy as the downpipe did.
Old Feb 11, 2010 | 05:04 PM
do i need to do anything when its put in b4 i start it? or can i just put it in and start it up?
Old Feb 11, 2010 | 07:29 PM
wizzo 8's Avatar
Not really necessary but you can unplug the coil packs and crank the engine till you get oil pressure.
Old Feb 11, 2010 | 09:21 PM
fromWRXtoEVO's Avatar
Thinking of installing my 9 turbo in by myself. The one i bought came with all the lines, the j-pipe, an o2 housing and all gaskets. My question is i know studs break between the turbo and manifold alot, is there somewhere i can get new studs in case this happens? Also id like to get a megan manifold to maybe bypass breaking studs. The turbo has 2 studs installed already are there 2 studs on the manifold side? Sorry for a dumb post but rather save $300 on labor when i can do it myself. thanks
The problem is never getting a stud replacement, your real problem is to break them and not being able to remove the old/broken one. You need to soak that thing and perhaps leave it for hours or even over night. Use new sockets, don't try to use old sockets as this might cause the socket to slip and strip the nuts.
Carlos
Old Feb 12, 2010 | 08:09 PM
im gonna be dropping it off at a friends house and soak the studs overnight. thanks for all the help
Old Feb 12, 2010 | 08:28 PM
n2oiroc's Avatar
soak them overnight then heat them up orange when you crack them loose. heat is the most effective tool with rusty exhaust bolts.
Old Feb 16, 2010 | 05:19 PM
I noticed when i checked the oil line that the gasket was torn in half. Anyone know where to get a gasket for that or can i use some kinda silicone based gasket maker for that? Im pretty sure its the oil line. its the line connected on the bottom next to the licp
Old Feb 16, 2010 | 05:32 PM
GaBe511's Avatar
I'm thinking about swapping in a 9 turbo to keep with my OEM upgrades, when you install, i would like to know the difference in power and performance.
Old Feb 16, 2010 | 07:29 PM
Alright ill let you know then what kind of difference it makes. it will be untuned though till i get my tune from cbrd. It was suppose to go in like 2 weeks ago but the snow has delayed it.
Old Feb 21, 2010 | 07:27 AM
Alright so after working on the turbo all day i can say it really sucked.... I had soo many problems all day long. my buddy didnt have a jack at his garage cause he forgot he let someone use it, so i used the stock jack with jackstands. i couldnt figure out how to get to the 1 bolt attached to the lower oil return line untill i took off the positive cable and heat shield off the starter. Also what was holding the turbo on after i took off the bolts to the manifold. Figured out there was a bolt from the o2 housing attached to the block. my dumb*** didnt drop the downpipe enough to see that bolt. soo if anyone swaps a turbo watch out for that. i have the new turbo on but not installed yet. i gotta wait about 2 weeks to get back and finish it. Turned out previous owner put evo 8 mr turbo back in. it had TD05-16G-10.5t on it
Old Feb 21, 2010 | 07:46 AM
erald01's Avatar
nooo your 05 is supposed to have a 10.5 hotside.
Old Feb 21, 2010 | 03:18 PM
Alright i thought a stock 05 was suppose to have a 9.8. ok thats cool thanks
2006EvoIXer
May 31, 2017 08:49 AM
Veronica
May 18, 2017 01:09 PM
Hiboost
Evo X How Tos / Installations
16
Feb 27, 2016 03:33 PM
boostnMA
Oct 26, 2012 07:21 PM
evo8mrr
15
May 28, 2010 07:33 AM
