map o2 eliminator or......????
okay well im looking at making some real big numbers on my IX stock turbo .... and im kinda confused on witch direction i should go to achieve the best numbers...
FIRST:
would you recomend the stock internal wg with say a forged wg actuator or
MAP Stainless Steel 38mm MVS O2 Eliminator Downpipe (http://www.maperformance.com/map-sta...s-mvs-evo.html)... please leave feedback as to why you would pick one over the other.
SECOND:
recomend a tubular manifold like fullrace or should i go with a ported mani. please leave feedback to witch one
THIRD
do you think s2's are good enough to make this kind of power or should i go a little bigger/aggressive?
like i said i am trying to produce some AWESOME numbers on stock turbo and my number one goal is 400 on straight 93 oct i plan on going sd and getting tuned by ttp
FIRST:
SECOND:
THIRD
The MAP MVS is a great piece, its holds boost much much better than an internal.
If you've got the money go with a good tubular(FullRace, JMFab, etc), you will gain some good power over a ported stocker.
The new GSC S2 model looks promising and you could achieve your goal with them.
Good luck
btw what are your other mods? 400whp on a dynojet is an achievable goal but you'll need a more than just regular bolt-ons to get there.
Good luck
Or that, but I can understand what the OP is trying to do by reaching a goal that seems hard for others and if he has a great set-up on the stock turbo, when he does decide to bolt-on something bigger his numbers will be awesome
Thanks
Thanks
this isnt my first rodeo as far as high hp evo(look at sig) im wanting to go stock turbo.... i know i could bolt on a red and be there but what fun is that who knows mabey ill grab the pumpgas record
couldnt say it any better.. i want to reach a goal that others seems impossible.... then down the road i can throw a red or black on
^i ran 12.01's on my old evo VIII stock 9.8 hotside. so i think 11.2 on a IX making 400+ is possible...... all about the driver but any way back on topic... i like the whole tubular mani and external waistgate but that kinda gets away from the "stock" look i kinda want to keep.. how much power would be lost in going with a ported stock mani and internal wg with forge actuator? i will also be usings maps ported exhaust housing just fyi.
FIRST:
SECOND:
THIRD
FIRST:
SECOND:
THIRD
2.Tubular manifolds will gain you some power up top sacrificing some mid range. Full-Race, JMF and I believe Shearer offer nice pieces. Won't give you great bang for your buck.
3.S2's should be plenty for your setup. I would stick with them unless you have a money tree in your backyard waiting to be picked.
Oh and to the OP, Not trying to discourage you, but 12.01 and 11.2 are worlds apart. Good luck!
FIRST:
SECOND:
THIRD
FIRST:
SECOND:
THIRD
We have only seen one car break 400whp on 93 here and it was using a 4" ETS FMIC.
Not really, I just talked to my buddy who switched from the FP 25psi WGA and EPM 02 dump to the MVS and he loves it, he said he can hold 2-3psi more than his previous set-up which was already great. I guess someone should test it out though.
We have seen our best results with a shearer O2 dump. I would pass on the rest. All I have seen is poor units that leak exhaust at idle and throw off both the car's AFR for short term fuel trims as well as the wideband used to tune the vehicle with.
