Synapse Synchronic BOV installed
Old Feb 8, 2010 | 09:12 PM
  #61
wizzo 8's Avatar
Originally Posted by boostedwrx
Post your results back wizzo! If what l2r99gst is saying is true, I could certainly try tightening my preload (although always heard others loosening it). Anyway good info to try! If it works I'll rock A+B because it felt like it vented the best that way.
I went to play around with the preload and didn't know till now that it was set to the softest setting. I did get my bov used. I always had the problem of the valve opening prematurely when I let off the gas slightly. Very annoying. I tightened the preload all the way and it fixed this problem but now it flutters even worse. I set it to the middle and now its the best between both worlds. I daily drive my car on normal suburban streets so now its very nice to drive without the bov letting off unexpectedly. When I'm in 5th gear and am on the gas slightly and hit about 10psi and let off it does flutter a bit but its livable and better than when in was in the soft setting. Note this is with port C and B hooked up. I might try ports A and A+B again with the new preload to see if it helps the flutter. For now B is doing pretty good with the preload in the middle. I'm assuming this is how it comes new.
Old Mar 18, 2010 | 06:34 PM
  #62
Chris77064's Avatar
Sorry about bringing this thread back from the dead. I installed my synchronic bov with A+B connected and I get the flutter exaclty like ^^^ this guy was talking about. When ever I was on just A or B it sounded like a sequential type bov under partial boost. WOT it sounded very crisp like stock. I'm not sure if there is an issue with just mine or how my setup is. Can you guys shed some light on this?
Old Mar 19, 2010 | 09:22 AM
  #63
Synaptic Evo's Avatar
Chris try to loosen the preload on the back of the BOV. or if you wanna talk about your set up shoot me a call at (858) 457 1700
Devin
Old Mar 20, 2010 | 07:28 AM
  #64
Chris77064's Avatar
Cool, I played with the spring preload and switched to port A only. For the most part the problem is gone. Get a little flutter under partial boost not wot or conservative driving. Thanks alot guys.
Old Mar 20, 2010 | 07:34 AM
  #65
boostedwrx's Avatar
Good deal! I need to find out how A+B runs with no preload spring...
Old Mar 25, 2010 | 06:08 PM
  #66
Chris77064's Avatar
I found an explanation to why partial throttle acceleration caused some fluttering/bucking. GM 3 port! The boost pulses very fast and the underside of the pulse causes thesuper fast actuating bov to vent. I am using only port A and the preset screw back out pretty far. I say 9/10 the prob is fixed. Port A is the best set up for this type of boost solonoid.
To be honest the synapse synchronic was engineered too well. The slightest lift off in 5th causes the car to flutter a little bit. I say this is a healthy compromise than to deal with a leaky stock bov. Love this part and recommend to everone. Cheers nuggas
Old Mar 26, 2010 | 07:33 AM
  #67
addo's Avatar
I've been adjusting the pipe from a T to a Y thinking it would help, it sort of did but under full boost it seems to dip in and out of pressure marginally. any ideas?
also will you be posting a video on youtube of how to delete the Port C boost pipe?
Old Mar 26, 2010 | 09:49 AM
  #68
This is a BOV has port c correct?
To solve this issue i would recommend the Port C Delete for your BOV. I currently run a gm 3 port on my evo with no issues.
Old Mar 26, 2010 | 12:58 PM
  #69
boostedwrx's Avatar
I used a Y adapter when I had A+B hooked up but didn't seem to make a diff for me.
Old Mar 26, 2010 | 02:13 PM
  #70
MarioTME's Avatar
would love to see any video or any guide on how to DIY delete your port C
cheers
Synapse ftw
Old Mar 26, 2010 | 04:36 PM
  #71
wizzo 8's Avatar
cheers
Synapse ftw
Me too especially since i will be installing my FPblack soon and it doesnt come with a boost fitting
Old Mar 27, 2010 | 10:51 AM
  #72
boostedwrx's Avatar
You can just send it in to Synapse and they will modify it for you.
Old Mar 27, 2010 | 01:21 PM
  #73
wizzo 8's Avatar
Its my DD so can't have the down time
Old Mar 27, 2010 | 09:40 PM
  #74
boostedwrx's Avatar
You don't have your stock bov?
Old Mar 27, 2010 | 09:56 PM
  #75
wizzo 8's Avatar
Nope
