rebild help
Old Jan 31, 2010 | 03:59 PM
luis p botas's Avatar
rebild help
I just got around to installing the block I received from being machined, and just started to install the stroker kit 2.3 on the Evo 8 block, with 100 mm billet crank with Manley high rods and JE pistons. After I installed the crank, torqued the APR bolts, then I begun installing the piston rods in the crank...as I finished doing the the very first one,I tried spinning the crank a bit,and...turns out the rods touch the block!Anyone knows why this happens, or/and has had this happening to them? Any input would be apprecciated...
Old Jan 31, 2010 | 05:00 PM
Murf's Avatar
wrong rod length I thinks read to stroke or not to stroke in the pinned threads..lots of info on rod lengths
Old Jan 31, 2010 | 10:12 PM
Teal2nnr's Avatar
Really? that sounds odd.....did you purchase a kit? or did you piece this "kit" together?
Old Feb 1, 2010 | 05:01 AM
JakeTheVIII's Avatar
Yea I hear/see that you have to remove some material from the block on some stroker kits.
Old Feb 1, 2010 | 06:51 AM
fre's Avatar
fre
That is normal for some rods. Some rods require some block modification and some don't.
Old Feb 1, 2010 | 08:18 AM
lemmysports2's Avatar
Originally Posted by fre
that is normal for some rods. Some rods require some block modification and some don't.
+1
