Evo injectors vs DSM injectors
Old Feb 2, 2010 | 10:38 PM
xRoguex's Avatar
Ok - Now I know an evo injector will always work on a DSM.
But will a DSM injector always work in an evo 8/9?
I was just informed that FIC makes separate injectors for the two platforms. And that the DSM variant has a "centering" piece on the tip and the evo does not.
Has any one ever heard of this?
Apparently it is only a problem in stock manifolds too - because most smim have the provision for either injector to fit.
I just never heard of this before and wanted some input.
Old Feb 2, 2010 | 10:50 PM
whiteflash's Avatar
That's interesting, I would have thought they would be interchangable either way. Anybody know the answer to this?
Old Feb 2, 2010 | 11:35 PM
EvolutinIX's Avatar
Got me, great question. It would seem they are either interchangeable or not, maybe there is more to it.
Old Feb 3, 2010 | 09:12 AM
xRoguex's Avatar
FIC lists two separate part numbers.
No one answered when I called today.
Blah.
Old Feb 8, 2010 | 10:15 AM
Ronnie Size's Avatar
FCOTM Winner
Anyone?
Old Feb 8, 2010 | 10:18 AM
travman's Avatar
That is correct...
The evo injector goes into the dsm with no modification but the dsm injector requires the tip to be ground down before it will fit.
this was the info i got from Jens @ FIC a long time ago.
Old Feb 8, 2010 | 12:50 PM
KTriplett's Avatar
can anyone elaborate considering i just bought some haha.
Old Feb 8, 2010 | 01:05 PM
travman's Avatar
at the tip of the injector is it straight or does it have a bell or flare shaped bottom to it...
Old Feb 8, 2010 | 01:09 PM
xRoguex's Avatar
Originally Posted by travman
That is correct...
I know this may sound ghetto.. but could you physically do it your self? Sanding stone on a dremel?
Old Feb 8, 2010 | 01:12 PM
travman's Avatar
yes you could
now that i think about it the evo ones still have a slight taper/bell at the end but not as big as the dsm ones......
- its been a while since i have had that style injector, been running the bosch injectors for almost a year and my brain only retains so much info before i have to send stuff to the recycling bin.
Here is a pic of the evo injector.......these are 850/880
Old Feb 8, 2010 | 01:16 PM
Silk's Avatar
Stock evo 550 injectors are often bought by DSM'ers looking for a cheap upgrade......
Old Feb 8, 2010 | 01:20 PM
travman's Avatar
yes - evo injectors work without issues in a DSM....
Old Feb 8, 2010 | 02:58 PM
KTriplett's Avatar
i think the question will dsm injectors work on an evo.
Old Feb 19, 2010 | 10:01 AM
warp9's Avatar
They work fine. They are in my evo right now without issue. PTE 1000s
Old Feb 19, 2010 | 10:08 AM
FCOTM Winner
Good to hear Max.
