installed boost controller, weird thing happening, need help
Old Feb 7, 2010 | 09:23 PM
InSw1TcHeDFlame's Avatar
I installed a hallman mbc a few days ago and went out testing it to get the boost set to what i want. after several runs, probably 20 or so, i finally got it set to stock boost 19-20 psi. i went to take it out today, and the first time i hit boost, it spiked all the way up to 27-28 psi, but then it stayed at 20 after that, it hit high boost 1 time. then i was on my way home from work, and it did the same thing, hit 28 psi just once, then stayed at 20 in every gear
anyone know why it is doing this or how to solve this problem???
Old Feb 7, 2010 | 09:28 PM
blownevo's Avatar
which vaccum lines are you running off of with your hallman?
Old Feb 7, 2010 | 09:32 PM
i did it the way where the bottom of the controller goes to the turbo outlet, and the side nipple goes to the wga, capped off the intake and stock solenoid, intake manifold is connected to bov, i did no t splitting.
Old Feb 7, 2010 | 09:41 PM
blownevo's Avatar
If you did it this way you shln't have any problems....
https://www.evolutionm.net/forums/ev...procedure.html
I've only seen problems from t-ing off the vacuum lines from the intake manfold and the bov/dv.
Old Feb 7, 2010 | 09:43 PM
thats the exact thread i used, the very first picture is how i did it
Old Feb 7, 2010 | 09:47 PM
blownevo's Avatar
what other mos do u have?
Old Feb 7, 2010 | 09:49 PM
3" TBE catless, s1 cams, wideband
Old Feb 7, 2010 | 09:53 PM
blownevo's Avatar
Usually the reason for spiking is because your wastegate hole is large enough, but your actuator is taking too long to fill with compressed air, so you temporarily overshoot your boost level.
Any actator mods whatsoever?
Old Feb 7, 2010 | 09:56 PM
not that was i told when i bought the car, and i havent done any
Old Feb 7, 2010 | 09:58 PM
blownevo's Avatar
The hallman came with two springs, which did u put in it?
Old Feb 7, 2010 | 10:00 PM
the mbc came with the car when i bought it, he had installed it before but took it off. in a box there was a bag labeled hallman mbc heavy spring, or something like that, and it was empty, so im assuming he put that one in there
Old Feb 7, 2010 | 10:01 PM
blownevo's Avatar
there shldve been a heavy and a light spring.
Old Feb 7, 2010 | 10:03 PM
BluEVOIX's Avatar
Double check the vacuum lines making sure they are not getting pinched.
Old Feb 8, 2010 | 08:06 AM
sparky's Avatar
Did you disassemble the Hallman and lube it? Maybe it is sticking.
