Turbo
Old Jun 9, 2002 | 04:46 AM
Tommy's Avatar
Turbo
Is it possible to install turbo from E6 Makinen to Evo 7 without any problems? Will be more eficient ?
Old Jun 9, 2002 | 08:28 PM
Tommy's Avatar
Blitz Nur Spec Exhaust
HKS Stainless Steel downpipe
HKS Racing Suction Kit (intake)
Blitz DSBC Type "R" boost controller (dual solenoid)
HKS S40G iridium spark plug
HKS 264inlet cam
HKS 272exhaust cam
HKS Valve spring kit
HKS adjustable cam gears
HKS Forged Piston kit
HKS Piston Ring kit
Billet con-rod kit
HKS oil cooler kit
HKS Head Gasket
Fuel Pump
With above parts I'm going to reach 1.8bar
Old Jun 10, 2002 | 12:03 AM
Tommy's Avatar
Of course,pls add Gems to the list.
Old Jun 10, 2002 | 02:13 PM
Michaelk's Avatar
Claude, you blonde!! The Gems can control boost by f.e. using the standard solenoid or even an aftermarket one. Tommy, I think you should drop the Blitz boost controller from your car as it looks quite well set-up otherwise. Get an Apex AVC-R or better a good solenoid for the GEMS to control.
Old Jun 10, 2002 | 03:42 PM
3171's Avatar
Tommy,
what kind of brakes/suspension/clutch are you running?
