Greddy Profec B spec II or Hallman MBC?
If you mount the Hallman as close as you can to the middle portion of the radiator the boost spikes will lessen. I get about a 1 psi variance with my stock IX turbo.
I've also noticed that porting the hotside and O2 housing helped it too.
I've had my Hallman for over 4 years now and have only had to change the rubber washers last year for maintenance.
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
If you have a good tuner I would get a GrimmSpeed EBCS. You will make boost faster and hold more boost to redline. I'm hit full boost 700rpm earlier then using my Blitz EBC. I also hold more boost at redline. I hit 28psi and hold 27psi at 7800rpm. GrimmSpeed and Tactrix is the best you can get. They both offer plug and play to stock ECU and a good tuner can work wonders with these things.
Here is my review: https://www.evolutionm.net/forums/se...peed-ebcs.html
Inprogress
34
Jun 10, 2008 06:47 AM
Shaun@AWDMotorsports
Feb 21, 2008 12:00 PM
El Boricua
38
Mar 31, 2005 07:20 AM
PocketAces
Oct 31, 2004 11:16 AM
