Idle issues: Help- VIDEO inside
Old Feb 23, 2010 | 12:26 PM
vtec2mivec's Avatar
I noticed your check engine light is on...do you know what from? I'd get it scanned see what codes come up......
Old Feb 23, 2010 | 01:09 PM
EvODavO's Avatar
Originally Posted by kuzma54
IMO it could be the cold weather..i am near pittsburgh and my car started doing the same thing when the weather broke cold...im goin to wait till it warms up a bit before i take it to Nate at TPG. once my car warms up its fine but that first 5 min or so does what urs it doing.
My car is being a garage queen rite now and is at about 60-65 degrees in there, I start it in there and get the same results, Its def not the weather but I though the same thing at first. thank you for trying to help though!
Old Feb 23, 2010 | 01:11 PM
EvODavO's Avatar
check engine light is on from the test pipe. I cleared the code and this problem started a few weeks later with no cel on. eventually the light came back on like it always does because of the test pipe.
Old Feb 23, 2010 | 01:13 PM
EvODavO's Avatar
OK my IAC is out rite now and it is clean as a whistle. I took a few pics.Its still out and i am trying to test it. I turn the key to the on position and it is doing nothing. Is this normal?
Old Feb 23, 2010 | 09:18 PM
Evotech8's Avatar
Did you do the IAC resistance (ohm) test with a voltmeter?
There is a post somewhere on evom that shows which pins to check on the IAC. Or look in a service manual to find it.
Old Feb 23, 2010 | 09:36 PM
JACS_06_MR's Avatar
It looks like you are having the same idle issues i had with my IX. mine was because i had a bad MAF. If you have a scanner that has live data on it plug it in and check the IAT (intake air temperature) and use a laser temp reader to check the temperature from the intake itself. they should be within 10 degrees of each other, considering that most scanners have a slow refresh rate. That's what I did and fixed my problem, my scanner was showing 99 degrees when i measured the temp at the intake it was reading around 65 degrees, so the ecu keep trying to compensate..
Old Feb 24, 2010 | 01:40 PM
EvODavO's Avatar
I dont's have a voltmeter. I'll look into getting one and test the IAC with it. Thanks!
Old Feb 25, 2010 | 06:42 PM
EvODavO's Avatar
Originally Posted by Fast_Freddie
Have you done a boost leak test?
I'm going to try a boost leak test this weekend.
