FIC 2150cc going lean after spool then settles to target?
Old Feb 24, 2010 | 03:54 PM
Colt4g63's Avatar
Is anyone else having this issue or heard of this out of these injectors?
Old Mar 14, 2010 | 10:33 AM
33bull's Avatar
bump for answers
Old Mar 14, 2010 | 03:01 PM
JohnBradley's Avatar
The original post was related to the AEM, the injectors dont do this out of the blue. 33 what issues are you having and is it stock ECU or a standalone?
Old Mar 14, 2010 | 03:30 PM
Colt4g63's Avatar
My issue was solved. What happened was I set my resolution higher then im used to tuning with on the AEM so that i could REALLY fine tune in idle etc and that threw me off a tad... at first anyway Also this was the 1st time i had tuned with these large injectors and was having to make larger changes then i had expected due to the higher resolution i had my AEM set on.... But after talking with Lucas at English Racing and discussing a few things i got it straightened right out with no issues! These injectors drive SOOO NICE and idle SOOOO NICE its honestly hard to believe they are 2150cc!!! So if you are even remotely thinking about these injectors stop thinking and call up English Racing and grab a set. You wont be disappointed!!
I jumped the gun a little with this post to be honest. Even the best of us have brain farts and paranoia from time to time.
Old Mar 14, 2010 | 03:58 PM
EmeryatSTM's Avatar
Since these have come out it is the only injector We even recommend. From anything needing a 1000cc and higher these are the way to go. But them once and be done!
-Em
Old Mar 14, 2010 | 04:03 PM
Blue Evo 8's Avatar
-Em
How much power can these 2150cc injectors handle?? like 600-900 Dynojet AWHP I would presume?
I'm curious to see how these work on the OEM EVO 8/9/10 ECU's
Old Mar 14, 2010 | 04:15 PM
lillev23's Avatar
-Em
Is that based off of price or performance?
Old Mar 14, 2010 | 04:35 PM
GotWheelHop's Avatar
I am running them on my 03 with factory ECU. Have nothing but rave reviews for them. They idle MUCH better than the FIC 950's and Denso 720's I have run in the past.
Old Mar 14, 2010 | 07:49 PM
As far as I know I was the first to run these and the ID2000s on a stock computer but I havent had a lick of problems. They idle with the O2 feedback on up to about 50psi base pressure and at 58psi they will idle but need setup in pure open loop.
I was at 55% IDC at 640whp, so mathing it out assuming a large enough pump that should be something like 1250+whp on gas based on how EvoScan reports IDCs. On E85 I would think right under 1000whp.
Our drag 1G Talon uses x8 1650s but is only actually using about 2000cc worth of fuel to make 1000whp. It has an extremely large fuel pump in it as well but is set to 43psi base pressure.
