Motor blown? Wont turn over...
Old Mar 9, 2010 | 04:41 PM
thedru13's Avatar
Wow.. Looks awful. rebuild that bad boy and fix it up good..
Old Mar 9, 2010 | 04:48 PM
gsrboi80's Avatar
Originally Posted by 20gmr
powned....lol my bad man. I thought for sure it was a bearing
LOL. He did a number on her for sure though man DAMN
Old Mar 10, 2010 | 05:45 PM
fishie36's Avatar
Can anyone confirm if these engines are interference or not?
Old Mar 10, 2010 | 06:09 PM
LV///R's Avatar
Yes they are.
Old Mar 10, 2010 | 06:15 PM
fishie36's Avatar
Originally Posted by LV///R
Yes they are.
Oh well that makes a lot more sense then, someone else said they weren't. So my motor died due to slipped timing belt.
Old Mar 10, 2010 | 06:24 PM
buchnerj's Avatar
Most likely. If it jumped a tooth or two and threw the timing off like that pistons contacted valves, which cracked pistons, caused them to seize and there goes the whole ball game. My vote would be just gut the whole thing out and start over with a new short block. Don't forget to replace the oil cooler, etc. Granted, this will be expensive, but it is better to do it right the first time then have to rip the whole thing up again.
Good luck with your build.
Old Mar 10, 2010 | 06:36 PM
bbyevo8u's Avatar
do you know the cause of the failure?
Old Mar 10, 2010 | 07:34 PM
iTune's Avatar
Damn.....
To the OP, was this the original timing belt?
Old Mar 10, 2010 | 07:38 PM
iTune's Avatar
Also, you said there was a cam bolt loose? On which side(intake or exhaust)? How loose was the cam bolt? Had the cam gear walked off it's cog?
Just wondering what exactly caused this as i don't know if the timing belt would slip very easily on it's own.
tunermt
AEM EMS
24
Dec 13, 2025 01:26 AM
Chris Lutey
Oct 7, 2016 09:29 AM
richoaus
Sep 11, 2016 11:13 AM
marinejensen
16
Jul 7, 2015 07:18 AM
anthonypazsd
Jan 31, 2010 03:01 AM
