APS BOV Sticking Open Please Help
Old Mar 11, 2010 | 05:18 AM
zeus1's Avatar
my aps bov is sticking open. any aps vendors please chime in as to how to remedy this. i have tried silicon spray which works for a couple of day but that is it. seems some are using mobil 1 grease with the same result. i have tried adjust the spring pressure to no avail. also i have emailed various aps vendors with no response as to how to address this. any help appreciated.
Old Mar 11, 2010 | 05:19 AM
MR Turco's Avatar
I had a buddy with the same problem at an autox event. We found some crap got in between the piston and the wall causing the piston to develop some burrs. We roughly sanded it down to clean it up and it was fine. If you can't see the burrs you might want to disassemble the entire unit and clean it up.
SEEnoEVO's Avatar
Check this thread out. May be helpful.
https://www.evolutionm.net/forums/ev...-vent-bov.html
Sorry...just caught the end. Seems Mobil 1 works for most but not you. Hmm. Maybe check for burrs
Old Mar 11, 2010 | 05:25 AM
zeus1's Avatar
thanks guys for the help
Old Mar 11, 2010 | 05:34 AM
zeus1's Avatar
ok so took the bottom off, mr turco when you say dissasemble the entire thing how did you do that?
Old Mar 11, 2010 | 07:30 AM
RockmanX's Avatar
what does it sound like on the car when its stuck just curious how the car reacts so i know for my personal information
Old Mar 11, 2010 | 07:51 AM
zeus1's Avatar
its a bit jerky when on part throttle. when on full boost its hard to tell without logging and seeing the afr ratio go rich
Old Mar 11, 2010 | 08:08 AM
MR Turco's Avatar
I didn't have to at the time, we could see the issue from the opening. You should, hopefully, be able to slide the piston out. I could be wrong in which case do what you can in the opening section.
Old Mar 11, 2010 | 08:09 AM
biggie5252's Avatar
Open the bottom. Take out the adjustment screw and push a allen key or similar through the adjustment hole and push everything out the bottom. This happened to me also. There wasn't any kind of burrs or damage. I just took it apart and regreased it with Mobile 1. It's never done it since. I take it apart and grease it once maybe twice a year.
Old Mar 11, 2010 | 08:59 AM
zeus1's Avatar
thanks!
Old Mar 11, 2010 | 10:12 AM
Appauldd's Avatar
+1 on disassembly and cleaning.
Disassembly and cleaning
1)remove the BOV from your car
2) remove 6 allen head screws
3) pry the end off
4) remove the adjustment nut and allen pin
5) push the piston out with a screwdriver
6) pay attention how the internal plate sits for reassembly
7) clean (wipe) everything throughly (don't use any degreaser or brake cleaner = destroys the viton O ring
8) apply Mobil 1 grease to the piston body and internal around the O ring and internal body
9) reassemble
9a) before installing the adjusting pin, wrap it with teflon tape
10) reinstall in your car
ADJUSTMENT:
1) start you car
2) look in the vent hole and see the piston moving (your initial start point should have the spring loose....not tight)
3) tighten the adjustment pin until the piston stops moving
4) done
Hope this helps.
Old Mar 11, 2010 | 10:30 AM
biggie5252's Avatar
+1 on cleaning while it's apart. I use crc maf cleaner to clean it. Actually I use maf cleaner to clean a lot of things.
Old Mar 11, 2010 | 10:57 AM
RockmanX's Avatar
3) pry the end off
9) reassemble
ADJUSTMENT:
1) start you car
4) done
Hope this helps.
man cant i just send it to you and you take care of it and send it back lol
Old Mar 11, 2010 | 01:02 PM
szeryf's Avatar
u have to clean it up!
Old Mar 11, 2010 | 01:34 PM
Appauldd's Avatar
Sure....you pay the shipping.
