Tuned, then all hell happens
Old May 20, 2010 | 11:21 AM
apagan01's Avatar
Originally Posted by cbareng
well the cars if finally up and running, turned out to be a lifted head....Shouldve put in the ARP headstuds while the cams were getting installed. Basically #4 piston was cracked at the top edge, and second of all the two corner head bolts were loose. We sent the head and block out for honing and machening. The pistons, rings, and bearings were all changed in all cylinders, and we also went and changed the manifold to a Buschur and the stock 9 turbo to a green...Going back on the dyno soon and ill will post the new chart as soon as the motor is ready to be ABUSED!!!!LOL
__________________
thats exactly what i thought as you mentionned plug #4 was bent hence giving evidence some metal hit it, check your turbo and valve seats that piece of metal went out the hotside wheel.
Old May 20, 2010 | 11:24 AM
grillpt's Avatar
Glad to hear your up and running again. You don't hear about these cars lifting the head to often, sucks it happened to you.
Enjoi926
May 31, 2017 06:47 PM
EVO KiiD
24
Sep 4, 2016 10:06 PM
fullm00nevo
Jun 9, 2015 12:30 PM
gvr4737
Dec 17, 2012 07:46 PM
black95tt
12
Jan 7, 2011 05:25 AM
