stock evo boost reading
Old Nov 4, 2003 | 11:51 AM
cityhugo's Avatar
hi everyone, i really need some help here, can anyone tell me what the boost reading is for a stock evo, i just install a boost gauge and my reading is i boost to 19psi and then drop to around 12psi and hold it there, it feel like the ecu is cutting the boost. is that normal? or i have a leak somewhere? is there a way to check, i also have hks intake, greddy e-01, hks ground wires. please help. i have run the stock boost controller and the e-01, same result
Old Nov 4, 2003 | 11:56 AM
93civEJ1's Avatar
mine holds around 18-19sih in 4th and 5th gear WOT....but other than that it seems to drop...my vacuum seems to read a little weird...I seem to see like 25 vac at idle...and 20 letting off gas, and then like 15-17ish when first starting the car....dont know if this will help??
Old Nov 4, 2003 | 12:00 PM
cityhugo's Avatar
urs hold at 18-19?? wow. what do u hold at 2 gear? mine spike to 19 then just drop to 10 right away. like a fuel cut, do u think the ecu is shutting my boost off? i went to a few shop and noone know what wrong
Old Nov 4, 2003 | 12:02 PM
93civEJ1's Avatar
i dont know about low gears...havent really looked....but i think it drops...its normal on the evo...but when i do a WOT run, I am usually on the interstate at around 70 or so...so i am in 4th or 5th when i do..??
also...my needle tends to bounce up and down a tiny tiny bit (not noticable without getting right upon it) at idle...
Old Nov 4, 2003 | 12:03 PM
1QWKEVO's Avatar
if your running a boost controller and your boost is that erratic, then I tihnk there is a tuning or install problem, it should be 11-12psi off and hold whatever psi you set it to run.
Old Nov 4, 2003 | 12:11 PM
sr20det91's Avatar
Stock boost on mine is:
4TH=19PSI
5TH=19PSI
1ST-3RD= 19PSI then tapers to 15PSI near 5k RPM.
Vacume is around 17 at idle.
Old Nov 4, 2003 | 12:12 PM
93civEJ1's Avatar
no boost control here....nothing on mine....i am stock....I have no worries about mine....seems to be fine..to me.......as far as him....i couldnt tell ya.
Old Nov 4, 2003 | 12:35 PM
cityhugo's Avatar
i am sure is not tuning and install problem, and there's nothing wrong with the ebc because when i am running the stock boost controller, it does the same thing, my question is, is stock evo suppose to only spike to 19 and hold at 12psi of boost on 2 gear? anyone?
Old Nov 4, 2003 | 12:53 PM
sr20det91's Avatar
That seems to be about right...give or take.
I have seen my car do about the same sometimes, other times it may not taper as much.
You have to take into account car to car variances weather conditions(temp and humidity) and various other factors. If you got a sub-par tank of gas your knock correction may change a bit therefore pulling back boost and timing a bit. It could be lotsa things.
Sounds like your boost readings are fine to me. Wait till you have had your boost guage for a while and you will have a better feel for what boost you see for various conditions.
Old Nov 4, 2003 | 01:01 PM
cityhugo's Avatar
but that still didn't answer y my boost just drops off after it hits 19psi, when i first got my car, it taper off, now it just drops, u can feel it, like a fuel cut, can it be my wastegate is no good? but i think the wastegate is only open and closed, no in between. would it be a boost leak? but i shouldn't be hitting 19psi at all if i have a boost leak. my only answer is that the ecu is somehow shutting my boost off, can the ecu do that? any thoughts?
Old Nov 4, 2003 | 01:04 PM
Jinu0808's Avatar
I really think it has to be a LEAK or something is connected wrong. Reinstall eveyrhting and use ALL NEW HOSES this time and check for any LEAKS .
Old Nov 4, 2003 | 01:10 PM
cityhugo's Avatar
but if i am leaking boost, how can i still boost to 19psi and just drop?
Old Nov 4, 2003 | 01:13 PM
Jinu0808's Avatar
then set the EBC lower this time at like 14 t o15 psi and see if it still drops .
Old Nov 4, 2003 | 01:14 PM
Jinu0808's Avatar
I had a Mechanical Boost gauge before I had EBC and EXHAUST my reads 19 psi then tapers to 16 psi.
Old Nov 4, 2003 | 01:16 PM
cityhugo's Avatar
yea, i did that, no matter what setting i put in, i will get the setting and then drop back to 10-11psi right after that
