400wtq+
Old Mar 28, 2010 | 05:16 PM
Boostfiend's Avatar
400wtq+
Apparently the 4g63 is not good for this amount on a Mustang Dyno so I wanted to know if I would be safe with Carillo rods and Cosworth pistons on a 2.0L. If that is overkill what setups are you guys running?
I'm sort of set on Carillo rods but just can't pick a piston.
Old Mar 28, 2010 | 05:19 PM
sho669's Avatar
carillo's are nice, a lot of guys run the weisco hd pistons.
Old Mar 28, 2010 | 05:21 PM
sho669's Avatar
it's always a good option in my book to have a solid foundation, don't really think it can be 'overkill' to build a decent shortblock. Build it once and you won't have to worry about it down the road.
Old Mar 28, 2010 | 05:25 PM
slvrr's Avatar
Originally Posted by Boostfiend
Apparently the 4g63 is not good for this amount on a Mustang Dyno so I wanted to know if I would be save with Carillo rods and Cosworth pistons on a 2.0L. If that is overkill what setups are you guys running?
I'm sort of set on Carillo rods but just can't just a piston.
How do you figure the 4G63 is not good for 400wtq? Lots of daily drivers out there with 400-450wtq. Not saying you shouldn't do a motor build I'm simply saying if your "only looking for 400ish wtq I wouldn't build it until you have evrything else out of the way.
Old Mar 28, 2010 | 05:26 PM
sliqdaddy91's Avatar
meth nets 400wtq quite easily pending on setups.
Old Mar 28, 2010 | 05:38 PM
05ah8james's Avatar
Better to be over prepared then under prepared.
Old Mar 28, 2010 | 05:42 PM
sho669's Avatar
+1 time bombs are not cool
Old Mar 28, 2010 | 06:12 PM
Boostfiend's Avatar
400wtq on a mustang dyno is a LOT. That said I have TOO much money in my head for me to ruin it on a blown motor. I'd much rather bulletproof my setup than be ****ed and have to pay another $14k for a long block + modifications again. It's just the cheaper route to go.
Old Mar 28, 2010 | 06:16 PM
big block ix's Avatar
I got a buddy on the stock motor/fp green making 440 tq on our local mustang at 34psi on speed Density open turbo
Old Mar 28, 2010 | 06:28 PM
Boostfiend's Avatar
Yeah, your buddy definitely has better luck than I do. How many miles?
Old Mar 28, 2010 | 07:35 PM
RockmanX's Avatar
every car is different just cause your friend is doing it does not mean we all need to exceed 420tq on stock internals. I personally think you have to be a idiot to do that but lot of folks do let them be on borrowed time then
Old Mar 28, 2010 | 08:06 PM
I agree with that^
I made 440tq with my 2.3L.. Then a month later my crazy friend made the same on his stock motor. He's really pushing it
Old Mar 28, 2010 | 08:12 PM
RyuEvoIX's Avatar
Old Mar 29, 2010 | 01:25 AM
Teal2nnr's Avatar
^^^ Idiot
Old Mar 29, 2010 | 05:10 AM
SmurfZilla's Avatar
Ryu I think you are the exception.....not the rule. While its encouraging to see where you've taken your car and where you want to go with it, but suffice it to say most of what you accomplished goes against most of the conventional wisdom found here and at other shops.
That being said; I will be taking my car to the ragged edge of reliability praying I don't fall over. If I do then a build 2.0 is in the future if I don't then I will be one of the so called ticking timebombs
