Evo will not turn over or start, but runs fine
Old Apr 1, 2010 | 08:57 AM
GetsidewaysD1's Avatar
I started my evo up the other day and went to the store. I came out of the store and went to start it and nothing. When you put the key in the acc all the lights come on, and you can hear the fuel pump turn on but when you turn it to the start position, the car doesn't start. Under the hood, you can hear all the relays clicking. I got a few people to help me push start the car and it started up just fine that way. I have done this several times so far and it drives perfect. I thought it was the starter so I ordered a new one and that didn't fix it. I looked over the engine bay for loose or broken grounds/wires but found nothing. Also looked at all the fuses but they are fine too. So I really have no idea what to try next. The evo is an 03 with ems and around 70,000miles.
Old Apr 1, 2010 | 08:58 AM
rgonyer's Avatar
Clutch switch?
Old Apr 1, 2010 | 09:03 AM
Originally Posted by rgonyer
Clutch switch?
No, I disconnected that a while back. Sorry I forgot to mention that.
Old Apr 1, 2010 | 09:13 AM
mitsuyager9's Avatar
If you have a a multimeter the best thing to do is check voltage to the starter and voltage on the signal wire to the solonoid...hope you can get it fixed soon man
Old Apr 1, 2010 | 11:15 AM
RockmanX's Avatar
you ever post pics of the bright car now. LOL man i can hear what the people were saying got this nice looking car with this wild paint job and cant even start it LOL. when in doubt drive it to the repair shop and let them fiqure it out.
Old Apr 1, 2010 | 04:38 PM
Lol, ya. It's the story of my life.
Old Apr 1, 2010 | 04:41 PM
VRSF Tiago's Avatar
This happened to me a long time ago, ended up being a fuse, 100 amp I believe.
Old Apr 1, 2010 | 08:21 PM
justboosted02's Avatar
battery
Old Apr 1, 2010 | 08:26 PM
05ah8james's Avatar
All good suggestions in here. Process of elimination
Old Apr 1, 2010 | 11:33 PM
EvoVIII808's Avatar
whats funny is i am having the exact same problem for the 2nd time. I installed a custom double pumper, and forgot to removed my test fit fuel hose . welp ended up blowing it apart, fixed it and now no start. Look at my fuel pressure and get 0psi.
Last time to get it to start i installed the stock ecu, and used EcuFlash to "Test" fuel pump. Basically primes it. Shortly after Car cranks and runs with no problem.
but i dont have the tactrix cable now, so maybe i will try to push start.
Old Apr 2, 2010 | 12:55 AM
Do you remember which one it was? Was it one of those black box ones? Is there any way to test them?
Old Apr 2, 2010 | 12:57 AM
Originally Posted by justboosted02
battery
I don't think so cause for one, its a new battery. Its less then 2 months old. Also like I said, when the key is in acc, all my lights and radio turn on.
Old Apr 2, 2010 | 01:49 AM
ReidFletcher's Avatar
Starter Relay. My Supra does this same thing and so do alot of other peoples. So someone wrote a Diy on how to install a relay which eliminates the problem.
Old Apr 2, 2010 | 09:56 AM
Where is this starter relay you speak of?
Old Apr 4, 2010 | 06:23 PM
wasabisnooter's Avatar
Dude u described my prob to the tee. +2 for the where abouts of the starter relay?
