damaged cam lobe pics inside
New pics after sanding lobe!!!!got these buddyclub 272's used on here one of the ex cam lobes has a small scratch almost dont think its a crack let me know what you guys think and if i should be okay to use them thanks
I wouldnt risk 6k for a new motor on the cams. as specially when they only run 700 for new cam. there is no real way to say if u will be "ok" running them, its a gamble and personally i would get new cams!
those marks are from over revved motor that bent valves. the rockers go loose and they mark the lobes. some sand paper to knock off the high spots and they are ready to rock. the 4g63 has roller rockers. they will roll right over the marks no issue whatsoever.
amazing to me so many in here recommending not use them. prolly not a single one qualified to change their own plugs. obviously no engine building experience at all. I have reused cams with much bigger marks than that.
My original post:
Originally Posted by iTune
looks like a small scratch. Prolly happend when they took them out.
To the OP, if you're really worried about this little scratch, sand it down with some super fine sandpaper, install the cams and enjoy them. Don't get all crazy with the sanding either, just a little sanding, so that you can sleep at night.
For everybody else, stop spouting ridiculous ish. It really bothers me, when people start pandemonia with misinformation. If you are not SURE of an answer, don't post anything, unless it reads, "I'm not sure" or, "I have no idea". Don't spread bull**** information. You guys are going to have the OP out buying more effing cams, for NO reason.
LMAO.....
