poll Dynoflash vs. Exede
I was waiting in line.... now I'm a very, very happy man.
The only downside to owning an evo, is no other car i get into now feels/handles/turns/grips to same. Every car feels like utter garbage to me now...
Yea.
Seriously though, my friends S2k even feels like it dips and dives more than the EVO.
My other friends M3 feels as big as a boat and turns like a sloth compared to the EVO. What ever am I going to do?
Originally posted by boostedwrx
Yea.
Yea.
Originally posted by MP5
Ive noticed you trolling around for quite some time lusting after an EVO with your bling acura. Well lets go troll hunting In the context of a tarmac/rally car what is one comprimise of the EVO? Cant name it? thats what I thought there is none it does what it was designed to do flawlessly it breaks better than 90K porches (BTW the breaking system is nearly identical) It accelerates as fast as Corvettes/NSXs/porches/M3s/Supras/RX7s. It turnes and handles a roadcourse as fast as any car ever produced Ferrari 355/360/Porches/M3s/Vettes/Nsx/RX7. Pretty great company huh small fry? The ONLY reason the price is so low is cause a budget shell(and all that goes along with that budget shell) is fitted to a
sportsrcar driveline. There is MASSIVE amounts of money in the all aluminum links and suspension components- All race quality.
So to answer you 32K comment some of us, the true enthusiasts who praid to Jesus it would come for the past 10 years lined up first. Those that rolled the Bling to the dealership for trade miserly waited for the market value to settle toward the end of the year cause they could jew out and wait - In other words they are just posers
You silly child!
If i can get back on topic here for a second. I have a question for MP5 or anyone that will take the time to answer. .. . .
It is about the Xede. I am not aware of how it wires in so will infer it like any other piggy i have used assuming that it will manipulate input sensor voltage to the stock ecu. Is this correct?
If so then i would like clarification , I guess in lamens terms, how this effects the stock ECU resolution concidering the it will compute and output the commands to the various drivers.
I can understand a previous post made by ez76. Very informative. But in my opinion not very clear.
Like any piggyback system you are "manipulating" actuall events to get a desired result. How acurate is the Xede or any piggy for that matter when it comes to timing advance or retard? How much room for compensation do you have in the MAF signal to vary the fueling the engine recieves. ? Is it only good for open loop operation? How about in closed loop? Do you have control over the O2 signal to the ecu?
Thank you for taking the time to answer my questions.
The piggy back can only move you from one cell to another in the stock map - its the stock ecu which controlls the timing or fuel based upon all the sensor input - - the piggy back attempts to move the ecu from one cell to aother but in this attempt can only manipulate two or three of many multiple sensor inputs
A big time compromise
Originally posted by DynoFlash
Good questions ! Piggy backs are band aides - they can bearly get the job done if you learn enough about robbing peter to pay paul you can get a decent tune with one - hardly optimal however
Or conversely, if the XEDE can "barely get the job done", does that mean that a reflash doesn't do the job at all?
Come on, Al. You can only spread your bs so far. After that, you just start to annoy people and insult their intelligence.
Shiv
Originally posted by shiv@vishnu
If, compared to a reflash, the XEDE can support more power, offer user-tunability, better knock control and better boost control without sacrificing drivability or safety margin, what exactly makes it "barely able to get the job done."
Shiv
Shiv
As with the XEDE for the WRX, the EVO XEDE is capable of close loop fuel and ignition control. However, the factory o2 feedback system will try to maintain a stoich AFR while closed loop is enabled. However, we can induce open-loop earlier (as we do with the WRX through the TPS tables) but have found that doing so is unnecessary for the EVO which transitions to open loop with little or no provocation. Likewise, it is also theoretically possible to feed the 02 signal INTO the XEDE and modify it to make adjustments for closed loop fueling. But that would only make sense if it didn't run lean or rich enough under closed loop conditions which isn't the case with the EVO or any other modern fuel injected car I've ever seen or tested.l
The XEDE and a Reflash offer TWO profoundly difference ways to tune your car. I find it amusing that AL, who has never used one of them (or has even tuned a car before a few months ago) feels comfortable making such sweeping statements.
My 2c,
shiv
Shiv,
I know the unichip was a problem for rexes as it tried to fool the ecu. It changed values the ecu was seeing in order to control it.
How is XEDE different from the unichip in this sence? Does the XEDE fool the ecu as the unichip did?
Also, what is the differences between your XEDE and UTEC?
Originally posted by meisnerboy
Shiv,
Shiv,
As for XEDE vs. UTEC, I'm not the best person to ask since my theoretical understanding of the UTEC is pretty topical. We've tuned several of them on the dyno but that's not enough to make any sweeping conclusions with respects to its strengths/weaknesses in relation to the XEDE.
My 2c,
shiv
My 2c,
shiv
My 2c,
shiv
I have more success with Turbo cars over the past three years that you
I was prob tuning my ole '66 Corvair with 4 carbs when you werent even born yet !
BTW since the Exede is such an amazing force in car tuning - I fully expect to see The ferrari F1 team adopt its piggy back stylings on next year's F1 cars
Tell me - if the Exede is so great - why are you going to sell reflashes also ?
