Help! Idle and Power Loss Issue
Old Apr 2, 2010 | 11:20 PM
Acree's Avatar
::UPDATE:: @ the bottom
There's a condition where the Evo will putter horribly. That's the best way to describe it. It just putters. For the first 60 seconds of start up, if I try to go above 3k rpm, the power just falls flat on its face. It doesn't do it every time I drive, probably 3 out of 10.
Today, the issue actually persisted past the initial 60 seconds and lasted the entire 10 minutes of my drive. There was almost ZERO power, and the idle was horrible sporadic. It almost sounded as if there was a misfire. We arrived to our destination, ate, and came back out about 40m later. The car started up and drove perfectly for the rest of the day.
I was wondering if anyone had any ideas as to what exactly may be going on. The only possibilities I've considered are 1) a boost leak 2)ecu issues. Any ideas would be helpful!
Mod List
Cams
All Piping
Intercooler
ECUFlash and Tune by English Racing
Full 3.5" exhaust
Cat delete
Zeixtronics Kit
100% Meth @ 10 psi
Tuned to 26 psi
Stock injectors, head, block, turbo, manifold.
-Acree
4/7/10
The problem is still persisting, but after talking to the original tuner, Aaron (sp?) at English Racing, the problem is typical. He said until coolant temps reach a preset value (130 degrees in this case), the ECU leans the car out so you don't damage the engine. I could have sworn I was giving the engine plenty of time (1-2m) but I guess that wasn't the case. Anyways, he said it's just typical of an engine with huge cams to take a very long time to warm up and have issues starting.
Old Apr 2, 2010 | 11:26 PM
LGshow19's Avatar
iac, throttle body seals, cam shaft angle sensor... the list goes on.
Old Apr 5, 2010 | 03:07 PM
Ludikraut's Avatar
Might wanna move this over to the Evo Engine / Turbo / Drivetrain forum...
l8r)
Alchem1st
Jul 28, 2017 01:15 PM
clanzkiller
25
Mar 15, 2017 09:55 PM
babaz7
Dec 2, 2016 03:25 AM
Acree
466
Jan 16, 2013 01:37 PM
Acree
Apr 30, 2010 12:58 PM
