Hows my flywheel? (pics)
Old Apr 5, 2010 | 08:29 PM
fishie36's Avatar
Resurface?
Reuse? (do nothing)
Replace? (why if so)
It came off the car at 85k still with the original stock clutch in good shape with some material left on it. I am switching to an ACT 6-puck sprung so I am trying to figure out what to do about the flywheel. Budget is tight so please dont just tell me to buy xyz lightweight flywheel just because.
Old Apr 5, 2010 | 08:42 PM
kane.s2k's Avatar
You can get the flywheel resurfaced for very very cheap. That would be what I would do.
Old Apr 5, 2010 | 08:44 PM
KenMasters's Avatar
Take it to a machine shop w/ a "Blanchard" grinder.
Good as new in about .009
Old Apr 5, 2010 | 09:23 PM
fishie36's Avatar
Originally Posted by HOTROD IX
resurface it and you should be good to go. how's the back side look?
Back side looks like normal, cast iron. No marks or cracks.
Old Apr 5, 2010 | 09:26 PM
evo unknown's Avatar
I am going against what everyone else is saying to resurface it. I would replace it with a lightweight new flywheel since you are in there doing the clutch, you might as well put all new parts in. However, if you know it is in good condition, must be since it came out with the oem clutch at 85k miles, then it may be fine to resurface.
Old Apr 5, 2010 | 10:26 PM
kane.s2k's Avatar
He specifically said he didn't want to buy a lightweight flywheel
Old Apr 5, 2010 | 10:40 PM
4RETECH's Avatar
I have seen worse just scuffed up and placed back in cars.
You could resurface, but just check the deck height after the clutch install.
Some shops take a little more off than they should, next thing you get shifting/ clutch disengagement problems.
If it was mine and money was tight, scuff it and put it back in. Hot spots don't seem to be that bad. just my .02
Hell, I'm still on my original!
Old Apr 6, 2010 | 06:47 PM
fishie36's Avatar
I think I can take it to school and run it on the flywheel cutting machine then. Thanks for all the suggestions!
Old Apr 6, 2010 | 07:49 PM
reconracer's Avatar
id take it to a machine shop and see what they say, as for doing it yourself as long as ya know what ya doing should be fine
Old Apr 8, 2010 | 09:32 AM
Steve_P's Avatar
as said, try to clean it up with some sandpaper, maybe 120-220 grit to start and see what it does. So I wouldn't have any downtime I bought a new flywheel for my DSM when I was changing the clutch. The OE one looked about like yours and it cleaned up in a few minutes and looked like new so I just reused it- 296k on it now.
Sideck
24
Apr 27, 2013 10:46 AM
talentsearch301
Nov 18, 2010 03:08 PM
Tanman1986
Sep 27, 2010 09:04 PM
talentsearch301
For Sale - Wheels / Tires
12
Jan 26, 2010 08:30 PM
rish197
Jul 9, 2008 09:01 AM
