Wierd and Dangerous Problem
Old Apr 7, 2010 | 08:27 PM
Werd's Avatar
So my car has developed an inconvienient habit of dying on highway entrance ramps. It happened once before in really heavy rain so I just assumed it sucked up a little water or something but today was completely dry and it happened again so now I see this as a problem. I think it may have something to do with the fact that I put in 1200cc injectors because it's also been starting really rough since then. It doesn't bog out or anything, it just dies, I don't even realize the car is off until I try turning lol. Spark plugs only have like 6k on them, car has 31k on it. I'm going to check the ignition this weekend. Any ideas on what could be causing this?
CAR HAS BEEN TUNED WITH ALL CURRENT MODS
Old Apr 7, 2010 | 08:32 PM
revvin9k's Avatar
You can't just throw in 1200cc injectors.
PaperClip's Avatar
loose battery terminal?
Old Apr 7, 2010 | 08:40 PM
06redrocket's Avatar
Please tell me you got tuned after the install?
VQChris's Avatar
I really hope your tuned with those 1200cc injectors.
Old Apr 7, 2010 | 08:41 PM
kwanza's Avatar
Perhaps no tune for the injectors may be the root cause as he said..
Old Apr 7, 2010 | 08:42 PM
Werd's Avatar
Why not?
That wouldn't matter after the car was started.
What's a tune?
I did. lol.
Old Apr 7, 2010 | 08:43 PM
R/TErnie's Avatar
If you got your 1200's tuned...and you're not completely lacking...
Compression test your engine, you may have hydrolocked it and bent a valve or shorted a rod.
I've personally shortened a con rod when a liquid to air intercooler sprung a leak.... still ran afterwards, but didn't make as much powa!
Old Apr 7, 2010 | 08:44 PM
ev0lution9's Avatar
is there any blown fuses?
Old Apr 7, 2010 | 08:46 PM
Werd's Avatar
Compression test was done a few weeks ago, pretty sure motor didn't actually hydrolock, it was just my way of writing it off and not having to do work lol. No loss of power or other signs of a bent internals.
Old Apr 7, 2010 | 08:47 PM
Werd's Avatar
I haven't checked but what fuse could have blown that would cause this?
Old Apr 7, 2010 | 08:52 PM
BluEVOIX's Avatar
I dont know about the EVO but loose battery terminal matters on some cars.
On my old 2003 Sentra SE-R Spec V , I left the battery terminal loose and it started dying on me randomly. I didnt know why until one day it wouldnt crank or have any electrical power. Thats when it hit me and I quickly tightened down the terminals and power flowed through to crank.
If the Evo is the same way make sure you tighten the terminals. A quick check would be to keep the car running and unhook one of the terminals and see if it still runs.
Old Apr 7, 2010 | 08:53 PM
R/TErnie's Avatar
Mod list and history of car please.
Old Apr 7, 2010 | 08:57 PM
Werd's Avatar
1200cc injectors, Kelford 272s, Supertech valve train and Forge Recirc are the only mods that were installed for this tune that began the problems. I also got Injen intercooler piping and intake, greddy tbe and o2 housing, and Walboro 255. Car hasn't really had any history to speak of. Nothing before I bought it at 14k and no problems since until now.
Old Apr 7, 2010 | 09:18 PM
ev0lution9's Avatar
the car starts right back up? if it doesnt you could have some type of ground out issue with your o2 sensor wires i had a similar problem but my car wouldnt start until i changed #7 fuse in the engine bay
