Wierd and Dangerous Problem
Happened again today and I think I've established the conditions which cause it to stall out. It seems to only happen when I'm accelerating and then suddenly hit the breaks and clutch hard. I feel like the engine is flooding or something but then I feel like it wouldn't start right back up so easily afterwards. And I checked all the fuses and everything was fine.
I'm gonna go with the way your Kelford 272s got tuned. Since you have alot less vacuum now with the new cams, the car tends to stall alot easier. Not sure who your tuner is, but adding more timing around regular idleing cells would help. Also if you have an Evo IX, you can mess around with the MIVEC maps.
Checked battery the other day, everything was fine there.
