car dies while driving....
Old May 26, 2010 | 03:28 PM
hitman28's Avatar
hey guys, i bought my evo few months ago, had a 1g dsm bov on it(?idk why). and it would randomly die out when i would get off the gas and push the clutch in when decelerating. ive since switched to a recirculated greddy type s (took all the precautions and read it all up on here) and it still does sometimes. the other day it died goin 40+mph. not too scary, but just an accident waiting to happen. any way to alleviate this problem? speed density, etc? i know it has something to do with the bov but cant pinpoint it
Old May 27, 2010 | 06:10 PM
shrty10135's Avatar
sounds to me like you need a tune.
Old May 27, 2010 | 06:14 PM
DannyMR's Avatar
i've had that happen to me with the WRX, turned out one of my head gaskets was ripped, after replacing that, never had the problem again
Old May 31, 2010 | 04:09 PM
hitman28's Avatar
aww geez, yea i plan on getting arp's and a hg when i change my timing belt
Old May 31, 2010 | 07:52 PM
kaj's Avatar
kaj
this does not sound like a BOV problem.
Old May 31, 2010 | 08:58 PM
hitman28's Avatar
^elaborate
Old May 31, 2010 | 09:10 PM
kaj's Avatar
kaj
I've never heard of a car shutting down, while cruising, due to a BOV. Especially if it's a recirc. However I'm also not an expert.
Have you checked your grounds?
Old May 31, 2010 | 09:21 PM
Still_Spinnin's Avatar
+1 could be a loose connection on something somewhere, Any codes?
Does the car loose power for a short second and come back or does the motor just shut off?
Old Jun 13, 2010 | 03:49 PM
evo_you_know's Avatar
I put a hks valve on my car for a while and it was not a recirulateing valve. I had the same problem with the car dieing when I would push in the clutch comming to a stop. or down shifting at higher speeds if i took to long to shift. i now have a recirculateing valve and do not have this problem any more... I have had the car tunned since then but I cant remember if that is what fixed it but I know it was one of the two.
Old Jun 13, 2010 | 03:57 PM
kaj's Avatar
kaj
You can't run a VTA BOV without having those issues. The MAF gets all outta whack.
The OP has issues that sound like they are due to something else.
Old Jul 10, 2010 | 05:09 PM
PR_DSM's Avatar
do a boost leak check, when i took my car to get tuned at STM it had leaks where i had no idea you can get them! a small leak will throw of ur AFR...
Old Jul 15, 2010 | 10:39 PM
tro0xazn's Avatar
You might have a leak, also when I used to have a vta bov (run the stocker now way better)
i noticed it would only stall out right after i boosted and "blew off" so you might wanna try it out and see if it only happens then. If its like that, you might be able to just take precaution and until you get it fixed don't blowoff while going through turns, but i don't see why you would switch to neutral during a turn anyways but GL
mykep83
May 18, 2015 04:15 AM
MuasEvoIX
Apr 27, 2015 07:20 PM
teudmunki9mr
32
Mar 29, 2010 12:16 AM
stitch_sack
May 23, 2009 06:23 AM
Mitchubishievo
Jun 30, 2006 06:36 PM
