Stealth turbo upgrades
Old Apr 12, 2010 | 02:33 AM
evogirl916's Avatar
Who has one!? I've been reading and researching and have come up with a few options. I have a BB 50trim thats been collecting dust for almost 2 years. I'd need more parts to complete the Hafe set-up, but it wont look 100% stock. BBK full is an option since many locals have proven it to be reliable for decent gains on a maxed out stock turbo car. BBK B might be an option, but the eta as of last week is still 60 days. Fp products have had mixed feedback so im pretty sketchy, but the Fp black sounds like a winner (if it doesnt fail). You also need all kinds of extra **** that add$ up for the install. Tomei has an ARMS m7960, but nobody has really talked much about it. Any input will be helpful
Old Apr 12, 2010 | 05:23 AM
sparky's Avatar
If you want to stay totally stealth, then the FP Black is out isn't it because of the larger ported compressor shroud and the non-stock appearing intake tubing required? The BBK, BBK-B, or stock looking FP HTA Green or Red would be your best bets. The ARMS Tomei has a non-stock compressor housing as well.
Old Apr 12, 2010 | 07:27 AM
Kracka's Avatar
The only current turbo upgrades that will look 100% stock are the MAP SST and CBRD BBK.
Old Apr 12, 2010 | 08:50 AM
RockmanX's Avatar
lol dont forget about the 64mm fp red hommie
stock looking to me yes you can remove the plate if you wish
Old Apr 12, 2010 | 08:58 AM
evo unknown's Avatar
BBK, FP Green, FP Red, FP Black, MAP SST, and Tomie Arms are all built off the evo 9 turbo housing. Therefore, they appear stock, even though they are larger.
There really is no need to go beyond a stock frame turbo unless you want to make 600+awhp. The Black is capable of 500+awhp on pump gas.
Old Apr 12, 2010 | 02:00 PM
evogirl916's Avatar
where does the black max out at? there arent too many people in nor cal running this bad boy
Old Apr 12, 2010 | 02:58 PM
RoadSpike's Avatar
AWD made 671whp on a dynojet with their black.
Old Apr 12, 2010 | 05:26 PM
o-townFLA's Avatar
Road Race Engineering GT3076r Kit
The RRE kit is nothing but HAFE parts but it does have a few RRE special touches added to the mix...!
Old Apr 13, 2010 | 01:27 AM
evogirl916's Avatar
OMG 671! thats bound to break something. reliability is a must! rather have less power and more reliabilty...rre kit is pretty stealth, but i spy an external wg
Old Apr 13, 2010 | 01:33 AM
RoadSpike's Avatar
Just get a red like I do and run it on e85 at 30psi this is definitely a fun turbo.
Or you could get a green,bbk turbo if you want the spool.
I see you are in my area so if you see a white RS wave
Old Apr 13, 2010 | 02:01 AM
evogirl916's Avatar
so you too understand the stealth factor which red do you have? power/tuner and pics of it installed please. thanks!
Old Apr 13, 2010 | 07:56 AM
Boosted Tuning's Avatar
Im also running the OG 64mm RED. Stock looking, including that it uses the stock induction tube.
And like roadspike said, run E85. You live in Sac, which is Cali's E85 heaven. You guys have like 12-15 station in the Sac area. So I think that is your answer.
Old Apr 13, 2010 | 08:04 AM
ChrisCarey's Avatar
We actually discontinued our turbo program a short time ago as we didn't have the resources or manpower to maintain it properly. You really need to dedicate all of your time and effort to be successful in that market. As such we will be running / recommending Forced Performance turbochargers from here on out.
Old Apr 13, 2010 | 08:31 AM
Most of us Cali kids love and understand stealth.
Here is pics of my 64mm FP RED. I also have a open element filter hiding in that stock airbox
Attached Thumbnails Stealth turbo upgrades-imag0076.jpg   Stealth turbo upgrades-imag0077.jpg
Old Apr 13, 2010 | 09:13 AM
RoadSpike's Avatar
I have the 64mm red just like the stock evo9 turbo. I should probably get the 80mm cover upgrade so I don't get 4th gear surge at low low rpm.
I run a stock ecu speed density conversion so my engine bay is slightly different than normal :P.
The Tuner is Me.
