Clutch help
Old Apr 13, 2010 | 02:27 AM
Mr1mike2001's Avatar
Clutch help
Looking for ideas on what could be a possible problem. I recently installed a competition Stage 4 clutch, everything went smooth for the most part other than the collar popping off and having to re-drop the the tranny. However after everything went in, and I drove it around the the good ole break in I noticed when I would go WOT between 5500 and redline the whole car would jerk and go. It feels like the clutch is grabbing but I dont have any idea on what I should do to correct whats going on then putting a new clutch in.. Any help
Old Apr 13, 2010 | 05:01 AM
APM Racing's Avatar
Did you torque the pressure plate down correctly and did you resurface your flywheel?
Old Apr 14, 2010 | 12:27 AM
Clutch help
Yes sir, all torques were done, and thats for everything. Motormounts, pressure plate bolting the tranny back to the block all of em. Is it a possibility it could just be something as simple as the bleed? I did have to replace the clutch master cyl to. And ever since doing that the clutch hadnt felt as tight as what it did before. Could not having a proper bleed possibly keep the pressure plate from fully dis-engaging allowing me to slip ever so slightly? The only other things I could think of was that my spline could be burred in a spot or the clutch is just bad. Im lost and coming up with crazynees out of thin air.
Old Apr 27, 2010 | 12:15 PM
Clutch Help
Im still hoping one of you guys can help me or point me in the right direction. The best way I can explain it is that the clutch pedal now feels spongy it holds the same pressure each day and I dont have a problem with it as far has having to bleed it everyday however I cant seem to get it any tighter then what it is. And the car is still doing a real quick jerk or two when I press the gas and go WOT. Its justa real violent jerk like the clutch slips for a split sec and then grabs real hard. Any ideas on what could be happening.
Old Apr 27, 2010 | 06:57 PM
Berts24's Avatar
you didn't say if you resurfaced your flywheel
