Best oil for tranny..
Old Apr 14, 2010 | 08:30 AM
ev0lution9's Avatar
Ok i know there is alot of threads about this but please read through. I changed the oil in my tranny right before the winter with redline. at the time i was told it was a very good oil and all but my car started grinding going into second ever since i put the oil in. not knocking redline but i dont think this is a coincidence because the car hasn't been tracked or abused and only has 15k miles now. anyone have any advice for me?
Old Apr 14, 2010 | 08:39 AM
gsrboi80's Avatar
You'll get 1000 different opinions here on this with no data to what actually is the best. I use Pennzoil Syncromesh and have for well over 100k. Trans is still bone stock and shifts great.
John at TRE recommended syncromesh to me ages ago with the recommendation of a change interval every couple oil changes or 6k to 10k. This advice has proved to work awesome for me and I wouldn't use anything else at this point until it gets rebuilt.
Take it for what it's worth. Shep I know mostly recommends Redline and John at TRE likes to recommend now the MR 6-Speed Diaqueen in both the 5 and 6 speed cars
Old Apr 14, 2010 | 09:53 AM
Ricekiller81's Avatar
Agreed
Old Apr 14, 2010 | 09:59 AM
andrewzaragoza's Avatar
you could also try amsoil. there are a lot of great reviews abt it.
Old Apr 14, 2010 | 10:15 AM
mifesto's Avatar
i put in amsoil in my transmission (diaqueen in tcase and rear diff)... i like it so far (driven about 1k miles)
Old Apr 14, 2010 | 11:26 AM
EvolutionTime's Avatar
Same here! I noticed a big difference in smoothness now since putting amsoil in the tranny.
Old Apr 14, 2010 | 11:30 AM
SavEVOIX's Avatar
So the 6-speed transmission fluid is fill and play? No issues or having to change fluid every 5-10k? I want OEM like fluid performance which will last me 30k.
Old Apr 14, 2010 | 12:20 PM
Gary@MellonRacing's Avatar
amsoil
Old Apr 14, 2010 | 03:58 PM
ev0lution9's Avatar
so go with amsoil and not OEM diaqueen?
Old Apr 14, 2010 | 08:14 PM
Spoolin4g63's Avatar
i've use diaqueen and redline! both have worked fine for me..
Old Apr 14, 2010 | 08:34 PM
dambikeracer's Avatar
Now what Redline oil did you put in you tranny? MT-90, MTL, or shockproof light? I just had my tranny rebuilt and I was told to run Pennzoil Syncromesh for the first 500 miles and then switch to Amsoil MTG or Redline MT-90 for more abuse.
Old Apr 14, 2010 | 09:10 PM
evo8daddy's Avatar
i broke in my trand with redline, then cjanged to syncromesh, then went to AMS oil now, which is by far the best fluid i have used in the tranny!!!
Old Apr 14, 2010 | 09:24 PM
ev0lution9's Avatar
i put the mixture that maperformance recommends i think it was mt90 and mtl mixed it only started grinding in 2nd after i put that in in cold weather..im going to switch asap
Old Apr 14, 2010 | 09:27 PM
EvoDan2004's Avatar
i run AMSOIL and it is working well.
Old Apr 14, 2010 | 11:04 PM
EvoDeez's Avatar
Redine Shockproof
Redline Shockproof working for me.
